thanks ben
Austin Mini Mk1 Super Deluxe Restoration
#1246
Posted 30 June 2015 - 09:21 PM
#1247
Posted 30 June 2015 - 10:01 PM
#1248
Posted 01 July 2015 - 07:13 AM
#1249
Posted 01 July 2015 - 06:26 PM
hi all got the body up on accrows and fitted the tank in tonight and re fitted the rear lights as they wasn't fully bolted in and the gasket seals wasn't tight enough against the body i had to file the holes out a bit more to allow the lights to push in more. the petrol tank neck is really tight on the rubber neck seal it will not push out anymore then this i am hoping petrol cap fits on i am pretty sure it was like this when i removed it tho early pictures will tell me if it was or not..
i don't suppose anyone knows what wires these are? i have the tank wires in and the bootlid wires but these ones are on there own at the back and there's not enough wire there to bring towards the bootlid at first i thought reverse light fog light? but they don't have them ? here is some piccys cheers tom
#1250
Posted 01 July 2015 - 06:35 PM
not many wires on a mini so should be able to sort with use of diagram.
#1251
Posted 01 July 2015 - 06:49 PM
excellent daz your right they are i never give it a fort. yes i put a neck foam seal but it was a white thin type i dont think it even touching the body.. you no when you fastened your tank strap was it hard to get to the bolt head? mine took me ages today to try and access it. im thinking i have something wrong. i have the little piece of strap coming from the seat bulkhead and then the longer piece from the boot floor up to a long bolt in the middle that tightens up? this how you done yours mate? cheers tom
#1252
Posted 01 July 2015 - 07:01 PM
#1253
Posted 01 July 2015 - 07:03 PM
same as what i did mate. the hole in the floor i had to drill this myself the tap goes threw the hole but not all the way.. what goes on the end of this? does it have to be used? as there wasnt any pipes on it when i stripped it.. cheers tom
#1254
Posted 01 July 2015 - 07:51 PM
#1255
Posted 01 July 2015 - 08:04 PM
ile get a fuel cap tomorrow and see how it fits on if it goes on then ile keep it as it is cheers tom
#1256
Posted 02 July 2015 - 01:37 PM
Welcome back, always loved reading through this getting ideas for my mk1, when ever the day may come that i can afford to even start it....
Looking like yours is coming along nicely lovely work and will be watching this one again top work man and awesome little car :)
#1257
Posted 02 July 2015 - 06:47 PM
hi today got the fuel cap fitted happy that it fitted nice with no trouble i think its because its a flat style one. i got the bootlid on with the number backing plate fitted i need some plastic bits and bobs to finish the bootlid of and then im going to sort out the wiring on clocks etc thanks tom
https://photos-3.dro...600&size_mode=2
#1259
Posted 02 July 2015 - 07:05 PM
