Looks like a Mini again, good job.
Austin Mini Mk1 Super Deluxe Restoration
#751
Posted 28 June 2014 - 03:19 PM
#752
Posted 28 June 2014 - 03:44 PM
looks good tom.
Glad you got it in the end.
So your deseaming the wing/frontpanel then?
Ben
thanks mate not bad for my first time got there in the end lol what i was going to do is weld the joins up and then grind a groove and shape it to make it a gap again but it will never crack and keep the water out the seem? what you think??
#753
Posted 28 June 2014 - 03:45 PM
thanks mate
#754
Posted 28 June 2014 - 03:59 PM
#755
Posted 28 June 2014 - 04:02 PM
hi daz cheers mate i thought by welding them it would make them stronger and i wont get any cracks in the paint work once its on the road shacking about. i only thought of it as the front subframe is bolted to the front panel. thanks tom
#756
Posted 28 June 2014 - 04:08 PM
looks good tom.
Ben
Like Daz said, It will be difficult to weld it and then get the seam line looking right. At most you can tack it at 1 inch intervals along the seam and then grind them back and V them out with a thin cutting disc.
A good sealant will be sufficient.
If you are worried about strength, then you can weld the seam from behind.
I would definitely avoid fully welding the seam from the outside. You will just create a tonne more work.
Ben
#757
Posted 28 June 2014 - 04:28 PM
true lol i dont want any more work. ile see what sort of sealent i can get..
#758
Posted 28 June 2014 - 04:33 PM
send a PM to petrol. He is the rust prevention wizard! He will give you advice on what products do the job best because he has spent alot of time testing them all out.
#759
Posted 28 June 2014 - 06:29 PM
Edited by Daz1968, 28 June 2014 - 06:30 PM.
#760
Posted 28 June 2014 - 06:46 PM
thanks for that daz i didnt really want to use sealant i wanted to do it like it was original and leave the metal line showing so it looks like it was when they was made but i was just wondering if i welded them up and grinded and etc to make them look more better... cheers tom
#761
Posted 29 June 2014 - 12:06 AM
fantastic progress tom! your flying along , its incredible :)
Hope you don't mind me asking, but did m machine modify your front panel for you? I spoke to them yesterday, and they can modify the rear window aperture to mk1 size if you want. I was wondering what the quality of the front panel was like if they have worked on it?
You cant be far away from paint now Tom?
#762
Posted 29 June 2014 - 03:56 PM
hi mate the front panel is really good and fits well. the rear panel yes m machine do a mk1 rear panel but its about £380.00 or more. i just mentioned what i had left and she said i may aswell buy the cheaper mk1 panel and use the bottom section of it.. have you sorted your rear panel now? how you getting on? thanks tom
#763
Posted 29 June 2014 - 03:57 PM
and yes m machine modified it
#764
Posted 29 June 2014 - 10:31 PM
Keep up the good work.
Andrew.
#765
Posted 29 June 2014 - 10:58 PM
it going ok thanks Tom, the mini is going backwards but life is good :)
Yeah, im going to get a complete back panel from them, as there more rust than i thought up in the roof and gutter areas. Was wondering what the quality of the welding and fit was where m machine did the work?
