Austin Mini Mk1 Super Deluxe Restoration
1604 replies to this topic
#736 ToM 2012
ToM 2012
  • 4,066 posts
Posted 26 June 2014 - 07:53 PM
Hi Tom
This is going very good - really nice work you have done from the beginning
Kind regards Nino  ;D
thanks nino  =]
#737 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 26 June 2014 - 08:20 PM
I need both sides but thanks anyway, the reason I asked the first question as I thought that panel you pictured was a couple of panels I needed (Corner boot floor and closing valance panel but all as one panel which it is.  Thats why I wondered where you got it as haven't seen it in stockists?
Thanks John
#738 ToM 2012
ToM 2012
  • 4,066 posts
Posted 26 June 2014 - 09:38 PM
i got mine from www.mmachine.co.uk was around £15.00 thanks tom
#739 ToM 2012
ToM 2012
  • 4,066 posts
Posted 27 June 2014 - 04:46 PM
not happy now! cant get these front wings to fit i have mounted the front panel and got the bonnet lip nice all the way around and i can not get nice gaps down the side of the bonnet but if i do get a nice gap it then doesnt reach the a panel edge? is there anyway to do this?? thanks tom
#740 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 June 2014 - 04:59 PM
Got any pictures of the problems mate?
#741 ToM 2012
ToM 2012
  • 4,066 posts
Posted 27 June 2014 - 05:29 PM
not as yet mate i took them back of the car and walked away lol.
#742 ToM 2012
ToM 2012
  • 4,066 posts
Posted 27 June 2014 - 07:07 PM
just had ago on drivers side again and it has lined up on the front ok and down the a panel seem but still a gap at the top of the bonnet but will push in slightly to close it. any ideas what to do? thanks tom
#743 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 June 2014 - 11:07 PM
To start with, try bringing the front panel down. That would probably make quite a bit of difference by the looks of it.
Ben
#744 jcslocum
jcslocum
  • 76 posts
Posted 28 June 2014 - 02:53 AM
I did some of this today and found the corner of the scuttle and the inner lip of the fender were hitting and I couldn't close the gap. I put a bright light inside the fender pointing up and the could see where things were hitting. Once i did some hammering and grinding it all,cane together.
#745 Nino
Nino
  • 178 posts
Posted 28 June 2014 - 09:48 AM
i had the same problem with my mk3.
my father and i came up with a crazy idea, for it.
first, we clamped the wing to the front panel, with MANY clamps
second, when we were happy with space between the wing and bonnet, and the wing-front line. then we closed the bonnet the line up the wing with the bonnet, up to the scuttle. - and fixed it with a screw the inner wing.
third, we put on the a-panel
fourth, we check'd if the wing and a-panel would meet. - if it look'd like it, then we gave the wing a little weld to the scuttle (not on the overside.. but in the corner near the inner wing.
fifth, then we welded a strong tube together with another tube and put it under the sub, and then straps over the front to pull the wings down in place. :)
- sorry if its hard to understand , because I'm not that good at the right expressions :) - but i hope it helps ! :)
we had a load on problems with it aswell and thats why we came up with this untraditional idea :)
Kind regrads Nino
- you can see more photos in my built :)
#746 Daz1968
Daz1968
  • 2,058 posts
Posted 28 June 2014 - 12:20 PM
Are they magnum wings as mine were same and I had to bend wing slightly to fit. I presumed mine was also down to non genuine scuttle repair panel
#747 ToM 2012
ToM 2012
  • 4,066 posts
Posted 28 June 2014 - 02:28 PM
thanks guys i have calmed down now and got the job done! after all that head banging on the wall its easy as pie. i have got them to the best i can get. the way i done it was have the bonnet down in position with the front panel and then push the wing in getting a nice line down the bonnet and then tack it in the top corner closest to the edge of the top of the bonnet to hold it there then pull it down and get the arch lip lined up and clamp in place then move on to the front line and pull it all in with some clamps at the back to hold it nice. i then tacked it in every so often around the front and around the scuttle and thats it you have it almost there just need to give it a fully weld to make stronger. i am going to be fully seam welding around the scuttle line and where it joins to the front panel as these places usually crack after fillering and etc so i am going to shape mine in with the weld.
i also welded the wheel clamp in the boot before i finished. let me no what you think here is some piccys thanks tom
#748 ToM 2012
ToM 2012
  • 4,066 posts
Posted 28 June 2014 - 02:31 PM
#749 ToM 2012
ToM 2012
  • 4,066 posts
Posted 28 June 2014 - 02:32 PM
also put some primer down the wing lines so you can see better what the lines are like
#750 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 June 2014 - 03:15 PM
looks good tom.
Glad you got it in the end.
So your deseaming the wing/frontpanel then?
Ben
