dont suppose you can send me a piccy of yours mate? so i get a rough idea? thanks
I,ve got one! haha
Stole from harrison's thread:
Posted 10 September 2013 - 09:02 PM
I,ve got one! haha
Posted 10 September 2013 - 09:05 PM
lol mine is ok on the top half but its rotten from 5" up from the bottom.
Posted 10 September 2013 - 09:06 PM
mmm just thought maybe i could reuse the bottom half of the other one maybe...
Posted 10 September 2013 - 09:29 PM
Edited by Daz1968, 10 September 2013 - 09:29 PM.
Posted 10 September 2013 - 09:47 PM
hi daz i will be changing the tunnel and cross member and anything else to make it look as original my toe board has totally gone and needs replacing all together i can see your only in dudley 10 mins away from me.
Posted 10 September 2013 - 09:59 PM
Posted 10 September 2013 - 10:06 PM
o yeh i know where you mean down the forge? by the college full of totty i member that road haha. well i might need pictures of how the fuel tank bolts in place and a few shots of the inside floor as when i got mine it had all rotted away and i had no idea what it used to be like. as its my second project and i am learning to weld at the same time its like i do something and im thinking should i be welding that part now or last kind of thing. cheers tom
Posted 10 September 2013 - 10:20 PM
Posted 10 September 2013 - 10:27 PM
cheers daz i will send you a pm when i get to the stage when i am in the boot floor i am sure m machine do most panels tho but are expensive i dont have the skill to make panels so i will have to buy them or see if any pop up on here or ebay. thanks tom
Posted 28 September 2013 - 05:25 PM
done abit today put rear arch in and cut a lot more rust away give me your thoughts if this will work by getting the lining up from this floor panel to the mk1 shell? also i have tested the mk1 sills and where the old jacking point is on the floor it doesnt line up with the hole on the sill panel? is there another way around this? also i can not do the sills as yet as i dont no if it will be in line with the shell when i drop it on the top? so i am kinda stuck and could do with your advise on what you would do next so i can get the mk1 shell on top of the floor temperately and just tack everything into place and do the full welding last once its all in line? thanks tom
Posted 28 September 2013 - 07:11 PM
Could i hav some better photos of your shells at present Tom to see where you're upto ? the outer sill's are the last job to be honest so put them to the back of the panel pile and forget about them for now.
Your next step would be to sort out all the mating surfaces ready to weld them together (i.e cut out replace rust ect.. on the front floor section of the donor shell, boot seem, inner sill top edges were you,ve drilled through need to be welded up so as you can then drop the mk1 shell ontop and spot weld in place on the doors and genraly working your way round, be sure to check the alignment before welding by clamping it in place fully everywere! and then spot weld whilst removing the clamps as you go along.
There are numorous areas i,ve probably missed for cleaning up which you'll obviously see before welding...like the rear parcel helf/bulkhead to boot floor surface flange, flitch panels, wheel arches on the mk1 shell ect... you'll see how it makes sense when you,ve done the above and have a couple people give you lift on & over whilst you or someone else gets it slotted in the right place.
Posted 29 September 2013 - 07:27 AM
hi mate i have cut one sill of allready and was thinking about welding that in place but i wont no where to weld to after i fort about it i am going to brace the mk1 shell up as much as i can this morning and then cut out my rear seat and etc and drop it on top of this to give me a ruff idea and then start dropping panels on and just tack them in place while i get it all lined up. ile get you some piccys today of what it is. thanks tom
Posted 29 September 2013 - 03:06 PM
I thought you'd fitted the doorsteps in tom ? well seeing as you're at that stage i'd advise you to get the doors mounted and doorsteaps welded in, to do that though you'll need to first sort out the A-panels and then mount the doors on there hinges, fitting the doors will allow you to align the doorste up from the inside whilt the door stays hut at all times so now you repeat on the other side and then the shell WILL be lined up correctly once you have it dropped ontop of the floor pan and slotted up on the floor pan to toe board join.
If i havn't explained well please say so
Cheers,
Cliff
Also: You'll need to be sorting this out, the boot hinge panel (Here: http://www.minispare...h/classic/Hinge panel.aspx|Back to search)
Doesn't exist on your mk1 so you'll need the above panel but weldiing ths panel in will mean (like the doors) you'l have to mount the boot lid on its hinges whilst tacking in place as the alingment needs to be bob on before you start welding
Posted 29 September 2013 - 03:15 PM
hi cliff i have emailed m machine what panels i want and i havent received nothing back from them as i wanted the door post stiffner i was going to put on a new rear panel if i could as its rotton on the top half to. cant really do anything to it untill panels come but i have put it in valuation area to see what it is worth as i might be selling it as i havent really got the time to work on it what do you think it is worth all together or splitting? thanks tom
