hey guys , so i have been tidying my taping my loom up on my mini but i have come across a problem , i worked from the alternator back and come to the starter loom the wires but as i unravelled it the white and yellow cable looks like its been cut :s i carnt seem to find a cable in the loom for it anywhere
8 replies to this topic
Posted 09 April 2013 - 07:23 AM
Posted 09 April 2013 - 07:49 AM
what year is your car? did it work fine before? I think it could be a 12v bypass for the coil looking at an old post on here.
Edited by petey81, 09 April 2013 - 07:56 AM.
Posted 09 April 2013 - 08:14 AM
1989 , it looks like it should connect to the starter solinoid to be honest as there is a small spade terminal there
Posted 09 April 2013 - 08:38 AM
Looks Like the one i wired for rev counter but I'm not to clever so don't take my word for it! :)
Posted 09 April 2013 - 08:46 AM
It is indeed the cranking bypass for ballasted ignition. If your car has been updated to one of certain types of electronic ignition or had a plain 12v ignition coil fitted then you don't need it. It should be insulated and taped back to the loom at both ends, as your unused tacho connection (white / black) has at the coil position.
Posted 09 April 2013 - 08:49 AM
found this if it helps http://www.minifinit...php?f=4&t=89255 I have same year and will check later as I re wired mine a while ago. .
Posted 09 April 2013 - 09:32 AM
cheers guys , i will pull it back out then as i am going megajolt so it wont be needed thanks for you help
Posted 09 April 2013 - 09:45 AM
1989 willhave a ballasted ignition. There will be a pink and white wire with resistive written on it which is the wire used to power the coil once the engine is started, and a yellow and white wire on turn over to give the coil 12v when cranking. (it wont be the full 12v as the starter motor uses a lot of power so usually about 10v)
as said above, this is all true if the ignition system is standard, if it has been converted to electronic, ask someone else
Posted 09 April 2013 - 12:07 PM
Woo i got it right!first time for everything!!
Mini Technical Sections →
Problems, Questions and Technical →
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 electrical |
Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 electrical |
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 brakes, electrical |
