Confused By Heater !
Posted 08 April 2013 - 08:26 PM
Can't seem to work out what controls the temperature setting , as no hot air came out !
Also dash air vents don't seem to work as seems to escape through heater box housing ?
Regardless , a very happy camper !!
any help grateful
Posted 08 April 2013 - 08:33 PM
Posted 08 April 2013 - 08:37 PM
the cable like choke on the other side of switch panel is on the early cars pull for cold in for heat and visa versa on later rover cars
Posted 08 April 2013 - 08:39 PM
Have someone pull the cable while you look
My cable didnt move the valve when I first got mine
Posted 08 April 2013 - 08:40 PM
iv had a mini (or 4) for over two years now and i still dont get it.
It's quite simple, you pull the control knob on the right hand side of the switch panel outwards, and it opens a valve that flows hot water from the engine into the heater. The ON/OFF switch on the heater controls the blower/fan, that pushes the warm air out of the heater and into the car. The direction control on the heater itself is to direct the warm air between CAR/SCREEN and OFF. "CAR" directs it down to the foot wells, where as "SCREEN" flows it up through plastic ducts to the windscreen demisters.
The air vents at either end of the dash are fresh air vents fed by ducts behind the front grille and are not connected to the heater.
Edited by AVV IT, 08 April 2013 - 08:47 PM.
Posted 08 April 2013 - 08:42 PM
Posted 08 April 2013 - 08:53 PM
while i have ur minds , what is the far left switch above heater next to heated rear window for , it doesnt stay in on position but does illuminate ?
Posted 08 April 2013 - 08:57 PM
Edited by AVV IT, 08 April 2013 - 08:58 PM.
Posted 08 April 2013 - 08:58 PM
i get the heater controls on the blower etc. the bit i didnt get was if the knob on the right of the switch panel was push or pull for hot because it didnt make a differance on my 1st car, it was always hot lol
Posted 08 April 2013 - 09:01 PM
Why? Was the valve it was connected to stuck in the open position, or was it just not connected to the valve and so not actually doing anything?
Posted 08 April 2013 - 09:07 PM
no idea, it never bothered me so never looked, kept the engine cool and i could always just open a vent or window lol
Posted 08 April 2013 - 09:49 PM
Posted 08 April 2013 - 09:57 PM
if you have the heater in the screen position and its not heating then simply follow the black pipes from the sides of the heaters up behind your dash, they sometimes have a tendancy of coming loose in my experience and just heating up your dash!
Cable tie or a few self tappers will stop that from ever happening
Posted 08 April 2013 - 10:03 PM
or sealing all the joints with duct tape
