Show Us Your Tamiya Rc Mini
148 replies to this topic
#91 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 10 June 2013 - 10:39 PM
Is that a 6R4 shell?
#92 1984mini25
1984mini25
  • 8,784 posts
Posted 11 June 2013 - 12:37 AM
yep, but I don't use it in case it gets damaged as it was £35.
That and I thought it looked nicer on the wall alongside the minis compared to the shell I normally run on that chassis witch is a bit battered.
#93 Scoop77
Scoop77
  • 508 posts
Posted 11 June 2013 - 05:45 AM
thats the best i'm gonna get it i think its still slightly out but i've been told you can't get them perfect
You certainly can't with all the slop in them :)
I use our 1/10 set up gear on ours.
You can if you set the steering linages with a digital callipers so they are both the same length. Also the slop is completely normal and helps makes the car much more forgiving, if you go and start shimming out all of the play in the steering and suspension you'll just end up with something that will handle odd and won't drive straight.
I agree that it's churlish to take out the slop but just setting the all the arms the same length won't give you a 'car on it wheels' true set up. You have to have set up gear for that.
#94 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 11 June 2013 - 07:10 AM
I do like that! Where did u get it from?
I know this isnt tamiya but i picked it up for 20p from a car boot, and yes its rc (well, it would be id it had the controller lol)
F8687A95-159D-440A-86D0-3377BD0113A8-489
#95 1984mini25
1984mini25
  • 8,784 posts
Posted 11 June 2013 - 08:13 PM
I bought it off eBay only last year, but the company/trader that was making them appeared to have disappeared towards the end of last year so currently aren't available.
Edited by 1984mini25, 11 June 2013 - 08:14 PM.
#96 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 11 June 2013 - 08:20 PM
you can buy estate shells that if you just paint over the rear window would look like a van, although there would still be a bit of window detail visible... I have one just haven't cut it out or painted it yet  :proud:  You can also get pick ups
Mike could you provide a picture of the clear shell?
Sorry only just seen this, yes i can...
#97 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,017 posts
Posted 11 June 2013 - 08:34 PM
Does anyone do a Clubman front one?
#98 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 11 June 2013 - 08:44 PM
http://www.theminifo...n-bodies/page-2
#99 Daviewonder
Daviewonder
  • 1,017 posts
Posted 11 June 2013 - 08:53 PM
I guess they're quite hard to get hold of then  :-(
#100 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 11 June 2013 - 09:00 PM
Extra pods to put your lights/led's in (& bumpers) -
Stickers (Pre cut masking tape is also supplied for windows etc) -
Comparison -
Hope this helps...
#101 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 11 June 2013 - 09:03 PM
could message him see if he can knock one up for you?
#102 Daviewonder
Daviewonder
  • 1,017 posts
Posted 11 June 2013 - 09:19 PM
Yeah I'll give it a go, thanks  :-)
#103 Scoop77
Scoop77
  • 508 posts
Posted 12 June 2013 - 06:00 AM
Is that a z car build in the background?
#104 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 12 June 2013 - 07:44 AM
Yup, my dads project, 'Busavan in zcars project section ;D
#105 Scoop77
Scoop77
  • 508 posts
Posted 12 June 2013 - 04:08 PM
Nice :)
