Best 175/50/13 Tyres
Posted 31 March 2013 - 11:06 PM
Posted 31 March 2013 - 11:34 PM
Posted 01 April 2013 - 10:53 AM
Ian
Edited by iwatkins, 01 April 2013 - 10:53 AM.
Posted 01 April 2013 - 11:18 AM
If you think their no good in the wet then, your not driving to the conditions of the road
Posted 01 April 2013 - 11:30 AM
Posted 01 April 2013 - 11:40 AM
They're not great in the wet, but as mentioned by a previous poster, if the road conditions are bad enough to push the limits of your tyres then its time to ease off a bit, they'll still stop and turn well, you just won't have the buckets of grip that Yokos give when dry.
Friends rate a certain Pirelli very, very highly, but never tried them
Posted 01 April 2013 - 12:23 PM
as above you cant expect miracles from a wide tyre on a light car in wet condidntions,
Posted 01 April 2013 - 05:08 PM
Posted 01 April 2013 - 06:35 PM
Posted 01 April 2013 - 06:48 PM
Posted 01 April 2013 - 07:48 PM
However, for use on a totally smooth race track, with very sticky slick racing tyres, a 13" wheel will perform extremely well so long as the suspension is set correctly and accurately.
For overall handling it's always believed that a 10" wheel provides the best results, although I must say that I've had 12" wheel Minis where the handling was excellent, wet or dry (don't forget, road-holding & handling are not the same thing at all).
Posted 01 April 2013 - 07:57 PM
Posted 01 April 2013 - 08:11 PM
My 165/50/12 yoko's on 12x6's is the best handling I've witnessed so far!
Are you sure they weren't 165/60 x 12 Yokos.
I have found that with those Yokos the road-holding is best with the pressures at about 30 front, 28 rear, but the best handling was at 32 psi all round.
I have never managed to make a 13" wheel Mini handle anything like a 10" or 12", although dry road-holding can be similar. Braking is much better in the wet with the narrower tyre on 12" or 10" wheels.
Some of it is personal choice and if someone likes the 13" wheel and is prepared to accept the reduction in wet-skid/slide resistance then that's OK.
Posted 01 April 2013 - 08:34 PM
That's what I meant... woops
13's just aren't right for a mini, I just think with the 12" you get the abilities of the 10" wheel and the minor advantages of the 13" as well
Posted 01 April 2013 - 08:53 PM
13" are fine for track use where the surface is totally smooth and wide and where ultra-sticky slick tyres can be used. With a 13" the reduction in side-wall depth makes the Mini suspension even less compliant and it's a good idea if fitting 13's to raise the suspension height a bit and use slightly softer damper settings so that the suspension can still work on bumps. The other thing which is not often considered is that the wider wheels and tyres, complete with the very wide arch extensions significantly increases the frontal area and thus reduces the maximum speed and increases the fuel consumption at cruising speed.
