Painting A Car With Cans?
#31
Posted 03 April 2013 - 10:32 PM
But too expensive for a decent gloss finish
Paint jobs are all in the prep
You can roll on cellulose and get a great finish if you put the work in!
#32
Posted 03 April 2013 - 11:18 PM
#33
Posted 03 April 2013 - 11:55 PM
Remember one thing
Preparation IS the paint job
Painting is easy, get all the imperfections, chips etc. sorted
Sand with 120
Panel wipe - Primer then sand with 800
Colour coats then wet sand with 1000
Lacquer x3 wet sand with 1500-2000
Then finishing wax like g3
Make sure there are no drips or rubbish in the paint between coats etc.
& your on to a winner!
Also buy all the paints from the same company and you shouldn't have compatibility issues
The above took hours and hours research from people that have done this for a living for 40 odd years!
Edited by mini*mad, 03 April 2013 - 11:56 PM.
#34
Posted 04 April 2013 - 06:40 AM
#35
Posted 04 April 2013 - 07:01 AM
Colour coats then wet sand with 1000 if its a base coat do not sand it, if its a solid colouer then no need for laquer
#36
Posted 04 April 2013 - 07:27 AM
http://retrorides.pr...ad=59578&page=2
#37
Posted 04 April 2013 - 10:05 AM
I can't find the one on here, but here is another mini that had a respray with ratlle cans and came out OK
#38
Posted 04 April 2013 - 10:10 AM
we also have limited space
#39
Posted 04 April 2013 - 10:39 AM
That way you get the mixing pre done and consistent all the way through
Is a few quid extra but saves a lot of hassle mixing paint!
You can just prime & paint with cellulose and sand it down and finish there as mdridge2 says
but lacquer will give you a deeper shine
And not need a major polish and cut every 6 months or so to keep looking fresh ;)
#40
Posted 04 April 2013 - 11:10 AM
Also would recommend getting RFU cellulose (ready for use)
when you mean mixing are you talking about me mixing it?because the can will be pre mixed cellulose paint so i wouldnt be mixing it :)
#41
Posted 04 April 2013 - 11:23 AM
The cans mixed by bidyshops are better than your 'normal' types, and a few fat caps from a graffiti supplier will help as they give a nice big spray pattern (helped my mate repaint his MX5 in graff paint, was seriously impressed with the coverage). You could use 'graff paint like Montana black. It's 'NC Combination' paint. The NC stands for Nitro Celluose. It's apparently not like cellulose car paint but it is like car paints from the 1930s! It can be cut and polished to a gloss pretty well if you wanted to so it can be treated in a similar way to celly. It covers really well and is available in every colour under the sun
#42
Posted 04 April 2013 - 11:25 AM
I bought..
5 ltrs celly paint
5 ltrs thinners
1 ltr bar coat
1 ltr primer filler.
I personally wouldn't bother with the laquer, its not necessary.
I would recommend bar coat though, with an old car you simply don't know what its been painted with in the past and the bar coat seals the old paint before you apply the new stuff.
#43
Posted 04 April 2013 - 02:02 PM
To paint this MGB in my garage with celly cost me about £150 in materials
I bought..
5 ltrs celly paint
5 ltrs thinners
1 ltr bar coat
was this with a compressor or cans of celly?
#44
Posted 04 April 2013 - 02:36 PM
did that make 10L?
and is it inside and out? :)
#45
Posted 04 April 2013 - 04:46 PM
Bing (1)
