Painting A Car With Cans?
54 replies to this topic
#16 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 01 April 2013 - 07:29 PM
You can get a good finish with rattle cans, but you do need to put a good few coats on. I would recommend looking at getting som 'fat caps' from a graffiti shop to get a decent spray pattern. Thing to keep in mind is that you're going to need 10-15 cans to get enough coverage to flat back to a shine, so it's not that cheap.
it will be roughly £150....but thats cheaper and easier than a respray as i can work on a pannel at a time...well thats what i thought anyway
Sounds like a lot of money to spend on a bodge to me. For that sort of price you could probably do it properly, as you could buy yourself a cheap spray gun, hire a small compressor for a weekend and respray it with celly. (which you could also do a panel at a time if you so wished)
Edited by AVV IT, 01 April 2013 - 07:31 PM.
#17 richw911
richw911
  • 2,084 posts
Posted 01 April 2013 - 07:44 PM
My spray job cost me £90 (we had compressor gun ect) using 2k. I could not afford to pay a pro so we had a bash ourselves, we made a booth out of wood and plastic sheet it turned out ok for a diy job had a few runs which we flatted back,its by no means perfect but not bad.
#18 MISSMADFORMOTORS
MISSMADFORMOTORS
  • 68 posts
Posted 03 April 2013 - 05:20 PM
so did you hire the compressor or already have it?
nice finish by the way really good job :D
#19 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 03 April 2013 - 09:27 PM
I've seen 1/2 decent rattle can finishes, although I think your 15 tins won't be enough, closer to 25 maybe 30.
#20 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 03 April 2013 - 09:31 PM
You can get good Rattle can finishes, but you have to spend the time at the end sanding and polishing the clear coat.
Spray cans will be Acrylic clear. :-)
#21 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 03 April 2013 - 09:37 PM
Unless of course the paint inside them is cellulose or 2 pack.
#22 jaydee
jaydee
  • 8,565 posts
Posted 03 April 2013 - 09:39 PM
Rattle cans are expensive and time eaters. I've done it once, never again. 2k all the way.
#23 Noah
Noah
  • 4,136 posts
Well, yes. But the clear that the OP was talking about. Halfords, will be Acrylic paint.
I didn't think you could buy 2 pack in spray cans in the UK anymore due to the chemicals, and the spraying without a booth thing.
#24 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 03 April 2013 - 09:42 PM
dont bother with rattle cans as youl be doing it all again in no time , 2k all the way ,hire a compressor and gun and do it right
#25 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 03 April 2013 - 09:45 PM
To paint a solid colour there's no need to clear coat, in this case that would also add 33% to the cost as well. Theres no mention of Halfords paint being used either.
#26 Noah
Noah
  • 4,136 posts
Posted 03 April 2013 - 09:53 PM
OP said thats where he got his test samples from. :-)
Yeah, I didn't say it would be cheap :P - Whats the finish like on cellulose paint?
#27 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 03 April 2013 - 09:54 PM
Hi
I see your glos aswell dont know if you have heard of them but middleton panels is a good paint shop to buy materials and paint from better than halfords and they make spray paint for you
by the way I want your wheels :D
yep thats where i got a test sample of the cans for the car and planning to get the rest.
To me that reads that the paint didn't come from halfords.
#28 richw911
richw911
  • 2,084 posts
Posted 03 April 2013 - 10:03 PM
@ MISSMADFORMOTORS I borrowed it for a friend :proud: thanks its not great in other places but better than i expected.
#29 iTomKart
iTomKart
  • 351 posts
Posted 03 April 2013 - 10:04 PM
We managed to do a DIY paint job for under £100 inc. paint, sandpaper, polish pads etc using cellulose paint and a spray gun. Much better bang for your buck than rattle cans, I would strongly suggest it
EDIT: We already had the gun and compressor though, but these aren't too much to hire as already stated
Edited by iTomKart, 03 April 2013 - 10:06 PM.
#30 iwatkins
iwatkins
  • 381 posts
Posted 03 April 2013 - 10:29 PM
Cannot help thinking a good paint shop would do a better job with much thicker paint for the same cost as a big pile of rattle cans.
When I did my AlfaSud, I did all the prep and did the blocking between coats, total cost for all panels was £220 including labour, booth and paint. Doubt you could beat that with cans?
But say you had just a roof to do, then I would consider cans, but would want to take my time and get lots of layers on with blocking between. Would take a while without a booth.
