What's The Best Place To Lift The Engine In
83 replies to this topic
#76 GraemeC
GraemeC
  • 7,472 posts
Posted 05 October 2019 - 09:21 PM
And trim the inlet manifold ears so it can be slotted in from above, over partially inserted screws. I use cap heads as I find long hex drive keys with a 3/8” drive easier then getting sockets and spanners in.
#77 I hate Brian
I hate Brian
  • 782 posts
Posted 26 July 2020 - 11:50 AM
Hi Graeme can you explain what you mean by trimming the manifold ears please, also have you got a fix for the difference in inlet manifold and exhaust manifold ears for washers as there is a thickness difference(im using a maniflow LCB and Minispares hif 44 inlet)
Cheers in advance
#78 nicklouse
  • 19,049 posts
Posted 26 July 2020 - 12:08 PM
Cheers in advance
have a read http://www.theminifo...ith-washerbolt/
the ears are the parts above and below the part that passes over the stud,
#79 Spider
  • 15,823 posts
Posted 26 July 2020 - 12:49 PM
WHO HAS THE ACTUAL ANSWER TO THIS THREAD !!!!! FOR GOD SAKES
"Officially" - see below.
"Unofficially" - any of those methods shown or at the end of my post here
Well just been having a read Mini Workshop Manual (A BMC Service Publication) thats the red A4 folder with the black writing Page A.10 "The Engine" section A.13 Engine and Transmission (Removing) and I quote "3) Fit lifting eyes to the second and fourth cylinder head studs at the front of the engine" un quote.
I'm not sure what workshop manual that was from, but this is from the Factory Workshop Manual
While that's the factory recommendation, this is how I've been doing them for nearly 40 years
Just of the Centre Head Stud (1 only)
#80 I hate Brian
I hate Brian
  • 782 posts
Posted 26 July 2020 - 12:51 PM
Cheers Nicklouse I did comment in that post,  by I chance came across this thread and ordered some bolts as per Coopermans suggestion but was still interested in the trimming of the manifold ears and a solution to the thickness issue. My thoughts were to reduce the inlet manifold flanges to suit instead of the washers ??
Thanks again for your input much appreciated
#81 cal844
cal844
  • 9,733 posts
  • Local Club: TFMOC
Posted 26 July 2020 - 01:36 PM
Stepped washers
#82 I hate Brian
I hate Brian
  • 782 posts
Posted 26 July 2020 - 02:29 PM
Have you done this Cal ?
#83 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 26 July 2020 - 05:08 PM
Just to add to the confusion surrounding the "official" way, here are some photos of my Workshop manual:
Cover:
Edition:
Manual Transmission:
Automatic Transmission:
Isn't consistency a wonderful thing?
#84 Spider
  • 15,823 posts
Posted 26 July 2020 - 08:41 PM
Bhahahaha,,,,, admittedly, I took that from a later manual than that one (1976 edition), however, I do have that same Red one you have (which appears to be 1st or 2nd edition), and I have a Blue cover version, which is also AKD4935 - 5th edition, and they show using that monstrosity bracket in that one for the Manual and Auto Engines.
I can't say why they had a change, maybe these lifting monstrosities weren't selling ? Though more seriously, they tended to change these procedures following an issue that occurred somewhere.
