As per the pic above - two front cylinder head bolts.
What's The Best Place To Lift The Engine In
#61
Posted 24 September 2017 - 03:43 PM
#62
Posted 24 September 2017 - 05:09 PM
I've lifted a ton of them out by attaching to the alternator bracket and the last exhaust stud on the opposite end of the engine from the alt.......use a large flat washer and tighten the chain loop against the head and it won't bend or damage the stud or head.
#63
Posted 24 September 2017 - 07:56 PM
#64
Posted 24 September 2017 - 09:39 PM
The studs in the picture look the same length on my engine, plenty of room to get the lifting brackets under. Your ARP ones must be shorter unfortunately.
#65
Posted 25 September 2017 - 08:06 AM
#66
Posted 26 September 2017 - 11:25 AM
#67
Posted 26 September 2017 - 12:08 PM
#68
Posted 14 October 2017 - 04:21 PM
#69
Posted 14 October 2017 - 09:11 PM
Well just been having a read Mini Workshop Manual (A BMC Service Publication) thats the red A4 folder with the black writing Page A.10 "The Engine" section A.13 Engine and Transmission (Removing) and I quote "3) Fit lifting eyes to the second and fourth cylinder head studs at the front of the engine" un quote.
#70
Posted 15 October 2017 - 02:39 AM
#71
Posted 15 October 2017 - 03:36 AM
Late to this post (and for all the haters)
#72
Posted 15 October 2017 - 05:22 AM
The spark plug method looks very innovative - as long as your welding is strong
#73
Posted 18 November 2017 - 01:33 AM
Now as you go back in, is it better to have a new LCB or sport exhaust manifold already mounted on the studs, or
snake it in after the engine is mounted in the car?
All my old stuff was going over my shoulder as it came out, now I'm hoping to find that "path of least resistance" for
all the new goodies going in..
#74
Posted 05 October 2019 - 09:43 AM
You will struggle to get the engine in with the LCB fitted, probably impossible. A suggestion I followed was to replace the manifold studs with bolts, much easier then to replace a gasket or remove/fit the manifold.
#75
Posted 05 October 2019 - 10:22 AM
I always use 5/16" UNF x 1.25" long screws to bolt the manifolds on. Been doing it for over 50 years like that. It just makes life so much easier.
