Jump Leads Price Vs Performance Testing
5 replies to this topic
#1 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 March 2013 - 12:27 AM
One of the thing we see here often is Flat Batteries, and anyone who runs a Mini as their daily transport usually has a set of Jump Leads.
The question is I get asked is why do I need to spend £30/40/50+ on Jump Leads when I can get some down the market for £3.99?
And the answer is VOLTAGE DROP!
If you take a pair of cheap Jump Leads they have 4/5/6 mm cables and the cable is made of a mixure of Alloys (Copper Is Expensive) and the first thing that strikes you is the cable is not what i would describe as Multi Strand (enen though it has 6 alloy strands) and when you first open the cables they feel like coat hangers in construstion, by that I mean that you can straighten them out and hold them up verticle, these were never designed to be long lasting or good performers.
Does It Matter Which Cable I Connect First
Yes actually it does
If the two jumper cables are attached together, as is often the case, then the positive connection must be completed first, and then the grounding connection. The reason for this reversal is that because the cables are joined, when one clip is fastened, the opposite one is left dangling near it, unless an assistant holds it up. The dangling clip is likely to touch something that is grounded, like the chassis or engine block. Therefore, the clip that is left dangling should be the negative one which is intended to be grounded anyway. If, incorrectly, the negative clip is connected, while the positive one, left dangling, touches something that is grounded, an instant short circuit will result when the corresponding positive connection is later made at the opposite end. For the same reason, it is also important not to connect both clips on one end first to one car, because then the clips on the opposite end of the cable may touch, causing a short circuit.
Cheap Jumper Cables
If you use a set of the cheap Jump Leads then you will find that when conected from the master sorce (the spare battery or another vehicle) upon cranking the leads perform badly, if the sorce voltage is 12v+ on cranking the voltage on the slave vehicle could be as low a 6-8v. These cables in my opinion are only suitable to supply current from the boosting vehicle to put a charge the dead battery.
After several minutes enough energy is transferred to allow cranking of the engine. If the connections are good and the cables are large, the boosting vehicle battery may also supply part of the cranking current. In an extreme case, it is possible to crank and start a vehicle with no battery in it if the cables are heavy-duty.
Cranking current drawn through light-gauge cables will damage them by overheating and they will melt and the insulation catch fire.
Due to the placement of the battery in the boot of the Mini and the possibility of hydrogen gas trapped inside the following sequence is followed when jump starting a disabled Mini.
  • Connect the two battery's (+) terminals with the red cable
  • then connect the earth cable to the disfunctional car's (-) battery terminal.
  • finally connect the remaining earth cable to the earth connection of the jump starting vehicle, on a point such as the engine block
  • This is done to avoid a spark which could ignite any hydrogen gas within the Minis Boot Enclosure
And remember if your Mini Battery is Completly Flat 0v and no sign of life on the dash warning lights, your battery needs replacing as a lead acid battery will never recover to provide good service.
Edited by KernowCooper, 29 March 2013 - 02:05 PM.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 29 March 2013 - 12:33 AM
I have found cheap leads won't start diesels!
The bitterness of poor quality lasts long after the cheap price is forgotten!
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 March 2013 - 12:38 AM
Make good hand warmers in the Winter though ;D I think they should be packaged as Disposible Cheap Jumper Leads :proud:
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 29 March 2013 - 10:16 AM
I don't think they should be called jumper leads at all because you can't jump start a 1.9 tdi Ibiza with them!
I must get round to buying a better set
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 29 March 2013 - 10:42 AM
Our old minibus at work had burn marks on the front from where our old handyman (handy in the loosest sense of the term) used cheap jump leads. I told him not to but he wouldn't listen, they had such high resistance that they melted the insulation and burned the paint off the bus. I finally managed to persuade the old boss we needed a decent set, but I made them up out of high quality cable and proper ends rather than buy a set. Not had a problem since in nearly ten years.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 March 2013 - 10:51 AM
Also good quality leads will have a braided cable inside each clamp joining the two parts. Without this the hinge rivet is the only thing carrying current from one side of the clamp to the other and this is not likely to make a good connection. Effectively the only point of connection to the battery post or the panel is the teeth of one half of the clamp, giving a total cross section of about 4mm if you're lucky. Get leads with good quality clamps and always make sure they are well connected to each vehicle to get the most possible cross section of contact.
Edited by Dan, 29 March 2013 - 10:52 AM.
