Posted 28 March 2013 - 09:36 PM
i own a 1984 mini 25 998cc and i cant find the main earth for the engine i wondered if anyone could help
thanks
Posted 28 March 2013 - 09:40 PM
Posted 28 March 2013 - 09:41 PM
Posted 28 March 2013 - 09:42 PM
Posted 28 March 2013 - 09:45 PM
it should be on the engine stabilizer bolt to the bulkhead just below master cylinders or failing that the center of the universe !
hi
theres not one underneath the master cylinder or near the engine stabaliser, the centre of the universe sounds right
Posted 28 March 2013 - 09:51 PM
look down on the right inner wing at the front, mine on a 1980 mk4 is there between inner wing and clutch cover bolts
Check there its closer its at the bottom on mine
Edited by KernowCooper, 28 March 2013 - 09:52 PM.
Posted 28 March 2013 - 09:52 PM
hi
weve checked there and its not there, weve looked in the haynes manual and all the places it says in there it isnt on mine, so it looks like my mini doesnt have an earth
thanks for your help
Posted 28 March 2013 - 09:53 PM
Posted 28 March 2013 - 09:57 PM
nope its not on the bottom on mine
Posted 28 March 2013 - 09:59 PM
If its cranking over you do otherwise your choke cable is toasted, I have seen them also on the right hand side at the front. you could always fit a new one on the stabliser if your worried
right ill try looking there
Posted 28 March 2013 - 10:04 PM
Posted 28 March 2013 - 10:22 PM
Do we have 2 Mini Lukes ? 1 and 2 ?? just answer this one up
looks like there is
Posted 28 March 2013 - 10:24 PM
Should run alongside the top engine steady, on the left hand side of the engine
theres not one there ive just jacked her up and looked at both sides of the wings theres none there, and along other bits and cant find one at all
Posted 28 March 2013 - 10:26 PM
Also tagged with one or more of these keywords: electrical, engine
Mini Technical Sections →
Problems, Questions and Technical →
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 electrical |
Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 electrical |
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
