its a great engine and I've used it in the UK when visiting shows......goes well on motorways
Posted 27 March 2013 - 10:32 PM
Posted 27 March 2013 - 10:36 PM
Posted 27 March 2013 - 11:04 PM
Well what?My current engines from minispeed and, well...
Posted 08 April 2013 - 11:11 AM
Well what?
Posted 08 April 2013 - 11:18 AM
Posted 08 April 2013 - 11:43 AM
Well what?
Well it leaks absolutely everywhere and I mean everywhere. I know it's a mini but a fully recondition unit shouldn't piss oil everywhere after 5 miles. It also has a crunch in second gear, jumps out of 4th occasionally and yes it was a reconditioned box too. Other than that as far as parts go and any other experience with them they've been great
Posted 08 April 2013 - 11:49 AM
Posted 08 April 2013 - 12:12 PM
Posted 08 April 2013 - 12:37 PM
Edited by Minilover1.3, 08 April 2013 - 12:48 PM.
Posted 08 April 2013 - 02:07 PM
Well what?
it shouldn't do any of that really should it, are they going to sort it out for you?
Posted 08 April 2013 - 07:08 PM
Posted 09 April 2013 - 09:24 PM
Well what?
If Im honest, I've called several times with various question and they don't know the answer. I called a while ago to find out what worm and pinion gears I had as my speedo was reading wrong. They told me and I then did some calculations via the guess work website and bought a new speedo to match the TPM that i should have had with the ratio they said. But it also read out so I did some calculations again and worked out that the worm and pinion ratio fitted was actually completely different to what I had been told so I guess they just gave me a random number to shut me up. As far as the jumping put of gears went they blamed it on my carpet when I didn't even have any... And my engine mounts which are all new and have been checked several times. The oil leaks they said would stop after a couple of hundred miles. I have now done over a thousand on it and it leaks even more. The head gasket even leaks and I have had the head torqued 3 times. So I have given up on hassling them because I never get a straight answer and I also live in Scotland so I can't exactly run it down to them. But as I say other than that, such as with parts they have been pretty good.
Posted 09 April 2013 - 09:28 PM
Posted 09 April 2013 - 10:40 PM
Well what?
that's just not good enough really is it. I mean oil leaks that would stop after a couple of hundred miles? really?
Posted 09 April 2013 - 10:52 PM
Where is best in the north west?
