Mini Restoration Service, Northampton
#151
Posted 22 August 2013 - 07:41 PM
#152
Posted 23 August 2013 - 05:50 PM
#153
Posted 23 August 2013 - 07:49 PM
It came to us like this..
Looks fairly decent... Until i started stripping the exterior...
Front panel was due to be replaced anyways but it needs more than that..
Lots of rivets along the arch lip, which started alarm bells ringing
There was a big area of primer on the drivers wing which seemed to be covering a patch of filler which needed to be sorted so i felt under the wing to see how big a dent we were dealing with, what i wasnt expecting was to feel rivets...
I then started to inspect the car further and found lots more rot
Petrol tank bracket was held on by sound deadening pads and a tack of weld
Rear arch is also rotten through
Centre of the front screen surround where it meets the roof also has serious corrosion
Some very nasty bodges in this one! Going to take a bit more than a quick blow over to get this 1 sorted!
#154
Posted 23 August 2013 - 08:12 PM
That looks pretty bad. Does this mean our mayfair is now not the worst one in the worshop?
Edited by jntabbycat, 23 August 2013 - 08:14 PM.
#155
Posted 23 August 2013 - 08:31 PM
#156
Posted 24 August 2013 - 08:29 AM
Edited by jntabbycat, 24 August 2013 - 08:30 AM.
#157
Posted 24 August 2013 - 09:36 AM
#158
Posted 24 August 2013 - 09:43 AM
how dya reckon ours will compare to this mate???
have you started on it yet?
#159
Posted 24 August 2013 - 09:55 AM
#160
Posted 24 August 2013 - 10:14 AM
#161
Posted 24 August 2013 - 06:38 PM
need to know where this car got its MOT! i am worried about mine failing next month :/
#162
Posted 26 August 2013 - 10:43 AM
we do have a car coming in soon as part payment from one of our customers which has a 1275 fitted, its apparently seized but we will check it out and see what its like and let you know
Is this me your talking about, becuase the car has a 988, unless someone else is giving you a mini as well.
#163
Posted 27 August 2013 - 05:05 PM
Hi
I'm trying to get my R reg rover mini back on the road. Everything is sound (scuttle is rotting a bit), but other wise it is only the passenger outer and inner sills. I was given a very high quote by southam mini as they only use heritage parts now. This is an Mot patch up for now, i'll get it done properly later, but i need to get the car back on the road asap. Any idea how much you would quote?
Chris
#164
Posted 03 September 2013 - 07:41 PM
#165
Posted 04 September 2013 - 11:15 AM
Bing (1)
