#16
Posted 19 March 2013 - 11:47 PM
#17
Posted 20 March 2013 - 05:57 AM
#18
Posted 20 March 2013 - 08:11 AM
#19
Posted 20 March 2013 - 10:57 AM
I think the comments made above forgot to include your 7 port head and twin Webers. The low end drivability will be considerably better than a 5 port. You should be able to get that to work from 2000 rpm in top gear without stumbling though it won't pull hard. I don't notice a lot of difference at 70 mph between a 3.44 and a 3.1, however I sure wouldn't want a 3.9 or 2.7.
I'm not sure you want to be down that low with a 286 and 1.5 rockers, the duration of the cam and that kind of overlap even with better breathing of the 7port head.
#20
Posted 20 March 2013 - 11:44 AM
#21
Posted 20 March 2013 - 12:37 PM
#22
Posted 20 March 2013 - 12:40 PM
#23
Posted 20 March 2013 - 12:42 PM
#24
Posted 20 March 2013 - 01:09 PM
#25
Posted 20 March 2013 - 01:16 PM
#26
Posted 20 March 2013 - 01:22 PM
#27
Posted 20 March 2013 - 02:06 PM
#28
Posted 20 March 2013 - 02:45 PM
I have a morspeed phase 3 cam which is very similar to a 276.
It idles at just over 1000rpm with an ultralight flywheel, power is strong from 2000-7000rpm and still had good torque for road use.
Edited by mike., 20 March 2013 - 02:45 PM.
#29
Posted 20 March 2013 - 03:50 PM
#30
Posted 20 March 2013 - 04:12 PM
This is probably the ' sensible' option, but you cant help thinking that you should have gone for the 286 a few weeks after you get it on the road and get used to the 276...
That's what I'm worried about :) I've never been known to go down the sensible route. Think 276 and 3.44 is popping up a lot and could be the best option.
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
