Oil Sump Washer
Posted 18 March 2013 - 02:47 PM
Posted 18 March 2013 - 02:49 PM
Posted 18 March 2013 - 02:57 PM
Posted 18 March 2013 - 03:04 PM
Thanks for the help fella <3
Posted 18 March 2013 - 03:16 PM
Posted 18 March 2013 - 04:15 PM
The advantage of the bonded seal is that it requires VERY little torque to seal and therefore over the life of your car there is less chance of stripping/damaging the threads in the sump.
Posted 18 March 2013 - 05:07 PM
Posted 18 March 2013 - 05:10 PM
Posted 18 March 2013 - 05:44 PM
Posted 18 March 2013 - 07:32 PM
Posted 18 March 2013 - 08:49 PM
The copper washer is probably your best choice after fitting a HeliCoil... however, you could try a 14mm nylon washer instead as it will crush easier than copper to create the seal.
Edited by dklawson, 18 March 2013 - 08:55 PM.
Posted 18 March 2013 - 09:51 PM
Seals better than a usual copper washer? Mine is leaking past the recent helicoil so I am looking for something to stop the cold oil leaking out. PTFE tape? Or some other thread lock?
Iv'e seen a few Helicoiled gearbox/transmission units and to be honest, unless you can get them within a very tight tolerance then they will often leak, one I saw was a few degrees out and the copper washer was never hoing to seal.
the oil should be sealed in by the copper washer, that is what it is there for so either replace the copper washer with new 1 or 1 of the dowty washers that where mentioned earlier or anneal the old washer (heat up till glowing then quench) if it is in good condition
Even annealing will not always cure this leak path potential :-(
Posted 19 March 2013 - 10:00 AM
