Oil Pressure Gauge
Posted 17 March 2013 - 07:17 AM
I know this has been asked before but I just wanted to get everyone's opinion on oil pressure gauges. Are they really necessary (I know if you rely on the warning light, the engine may already be dead)?
Another question is whether to go mechanical or electrical. Both have advantages, the electrical has the added advantage of not having to plumb a pipe into the cabin but are generally not as accurate. The biggest problem I can see with the mechanical ones is that it must be a bit of a nightmare if you ever need to remove the dash.
Any thoughts would be great. Thanks in advance.
Cheers,
Jon.
Posted 17 March 2013 - 07:46 AM
I'm sure I've read about oil pressure switches which make the light come on at a higher pressure possibly preventing damage but a gauge shows the oil pressure being too low as well as too high and too high can do damage as well
Posted 17 March 2013 - 07:47 AM
Posted 17 March 2013 - 09:54 AM
Posted 17 March 2013 - 10:47 AM
But dont do what i did, take the dash off the fix a loose wire to the rev counter, start the car to check its fixed and forget to reconnect the pipe to the guage, oil all over my brand new carpet
Posted 17 March 2013 - 10:58 AM
Posted 17 March 2013 - 11:14 AM
Posted 17 March 2013 - 12:22 PM
Posted 17 March 2013 - 01:02 PM
is it generally easier to plumb in a mechanical one than a electric?
I would not say easier, I would say "different".
First, it is no harder to remove the dash where a mechanical gauge has been fitted than electrical. In both cases you would need to pull the dash forward enough to disconnect the gauge (spade lugs and a lamp on an electric installation, a small fitting and a lamp on the back of a mechanical installation).
In both cases you will run "something" (wire or oil line) from the dash to the engine. As mentioned by Mattbeddow, on the engine block you will either replace the existing pressure switch with the electrical sending unit for your guage OR with a pipe fitting for the oil pressure gauge. You can use a "T" to run both the existing warning light and the gauge. Keep in mind that you will NOT connect an electrical gauge to the pressure switch. You MUST use the appropriate sending unit for the electrical gauge.
With the electrical installation you have to source a 12V supply for a light, power for the gauge, and an earth for the gauge. The sending unit wire is generally easy to run as it will be very flexible. There are a few Smiths electric oil pressure gauges. If you opt for one of those, the required power will not be 12V but 10V. This means you would connect the gauge to the output of your existing voltage stabilizer. That can complicate things. Aftermarket electrical gauges will have an internal voltage stabilizer and will be easier to install than Smiths.
With the mechanical gauge you will have to supply lamp power and an earth but no other electrical connections. There are at least 3 possible method of plumbing the gauge to the block. There are inexpensive nylon tubing kits, copper tubing kits, and stainless braided hose kits (listed in increasing cost and preference). The nylon kits work OK but the plastic hardens over time and is easily damaged. The copper kits last a long time IF you loop the extra tubing into a spring shape to absorb engine vibration between the block and firewall. They are obviously more robust than the nylon and only cost a little more. The braided hose kits are really nice and very durable. Typical construction has a PTFE tube inside a protective stainless overbraid. They are as flexible as the nylon and more durable than the copper. However, they will cost quite a bit more.
I prefer mechanical oil pressure gauges for a couple of reasons not mentioned yet. Mechanical gauges respond faster. Some (but not all) mechanical gauge have more degrees of sweep. While the needle of an electrical gauge may only move 90 degrees across the gauge face, many mechanical gauges will have a needle that sweeps 270 degrees around the face. This allows for larger and easier to read scale graduations.
Regardless, an oil pressure gauge is very reassuring (to a point). I do want them in my car I drive but almost everyone who installs one for the first time then starts asking if their car's particular oil pressure is "OK" or if they have too much or too little oil pressure.
Posted 17 March 2013 - 01:08 PM
Cheers,
Jon.
Posted 31 March 2013 - 02:35 PM
Posted 31 March 2013 - 02:49 PM
Posted 31 March 2013 - 03:14 PM
Posted 31 March 2013 - 06:17 PM
