Mpi Not Starting, No Spark Situation, Coil Pack Check
20 replies to this topic
#1 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 16 March 2013 - 07:09 PM
Hi all,
I have put the attached document together to help diagnose the no spark situation that many seem to suffer from.
I am no expert so it may not be 100% accurate or use the correct terminology. I would therefore welcome any feedback or suggested corrections.
The coil pack used in the document comes from a running mini.
edit: the tachometer relies on a signal sent from the coil, logic would say that a faulty coil may affect the tach reading.
Edited by Fast Ivan, 06 May 2016 - 03:08 PM.
#2 nev_payne
nev_payne
  • 2,249 posts
Posted 16 March 2013 - 07:49 PM
Someone's tooting for a Doctor promotion :lol:
#3 Ipod
Ipod
  • 2,024 posts
Thanks for that, iv added it to my fav's as a just incase :proud:
#4 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 16 March 2013 - 08:24 PM
not at all, I'm still learning myself.
I just thought the no spark situation seems to be quite common and that its bound to happen to me at some point, so a bit of research, reading and playing was in order.
#5 Mikalv
Mikalv
  • 39 posts
Posted 17 March 2013 - 09:43 PM
Great stuff man! Thanks a lot!
#6 ojames
ojames
  • 32 posts
Posted 18 March 2013 - 01:27 PM
Rob Mac, I diagnosed mine with this guide, the numbers read different from what are specified. If my issue is the coil I'll post the ohm ranges. The bottom two cyl 1 & 4 were different from 2 & 3. and the pins were different.
#7 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 28 March 2013 - 08:09 PM
sorry guys but I made an error with the figures for the resistance values on my guide.
the correct values are 0.41 to 0.61.
I have ammended the guide, the old one has been deleted, the attached document above is now correct.
#8 BillyBoy1993
BillyBoy1993
  • 40 posts
Posted 15 June 2013 - 02:22 PM
Hello Ive just done this coil pack test on my mini and the results  are 7.38 for the top two pins and then bottom two pins are 12.67. i assume the coil pack is faulty? and could this be the cause of the car not cranking at all when i turn the key?
#9 Ipod
Ipod
  • 2,024 posts
Posted 15 June 2013 - 06:27 PM
Is the battery charged? ;D
#10 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 15 June 2013 - 06:55 PM
the reading is out of spec, but don't bin it just yet, your problem of not cranking when you turn the key will not be solved with a new coil pack. a faulty coil pack would not prevent the engine from cranking, it wont fire up but it would crank over
is the immobiliser working ok?
Edited by Fast Ivan, 16 April 2016 - 06:20 PM.
#11 BillyBoy1993
BillyBoy1993
  • 40 posts
Posted 16 June 2013 - 12:46 AM
Yeah its a brand new battery and been charged haha :D .Yeah the imobiliser light turns on and off fine last weekend connected a battery directly onto the starter motor which made the engine crank but wouldnt fire so im thinking it could be the solenoid and coil pack are playing up ?
Edited by BillyBoy1993, 16 June 2013 - 12:47 AM.
#12 Ipod
Ipod
  • 2,024 posts
Posted 16 June 2013 - 12:54 AM
Have ya reset the fuel cutoff switch
#13 BillyBoy1993
BillyBoy1993
  • 40 posts
Posted 16 June 2013 - 12:56 AM
Yeah thats the black button near the wiper motor isnt it ?
#14 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 16 June 2013 - 06:36 AM
Yeah that's it by the wiper motor. When you turn on the ignition does the fuel pump prime?
I think its unlikely, not impossible though, for both the coil pack and the solenoid to fail at the same time
Edited by Fast Ivan, 16 April 2016 - 06:21 PM.
#15 BillyBoy1993
BillyBoy1993
  • 40 posts
Posted 16 June 2013 - 10:51 AM
Yeah the fuel pump primes once the keys turned and then you just get a click from the relay box
