i have the vibe black air component set i got them secondhand, speakers cross overs and tweeters
firstly the speakers have 4 terminals, 1 pos and neg saying 4ohms going to the cone area, and another pos and neg saying 4ohms going down towards the magnets, what are these?
second the tweeters have sealed wires on them (i think) and a black and black with a white stripe wire coming out, is the stripe one likely to be the pos?
also what size cable should i use cause i was going to use 4mm flex cable but the cross overs terminals are tiny!
cheers
Vibe Component Install Help
tonykart19
, Mar 13 2013 08:50 PM
Best Answer tonykart19 , 29 April 2013 - 09:17 PM
the two terminals were so the tweeter could be mounted in the center of the speaker
Go to the full post
3 replies to this topic
Posted 13 March 2013 - 08:50 PM
Posted 13 March 2013 - 11:14 PM
Can you take a pic of the back of the mids.
And a quick test for polarity for the tweeters, if you see the (little) cone but the leads on to a AA or 9 volt Battery, when you have the + and - wired correctly the cone will come forward if it's the wrong way around it will go backwards.
Posted 14 March 2013 - 05:35 PM
oh clever, il get a pic tomorrow thank you
Posted 29 April 2013 - 09:17 PM Best Answer
