Compression Test Results Advice
Posted 12 March 2013 - 05:32 PM
The first results are
Cylinder 1 - 150
Cylinder 2 - 130
Cylinder 3 - 130
Cylinder 4 - 160
Then whilst looking into other people's results i realised that i hadn't held the throttle open whilst turning the engine over, so i repeated the test again. Here are the results from the second test;
Cylinder 1 - 160
Cylinder 2 - 120
Cylinder 3 - 150
Cylinder 4 - 170
By this stage i was getting quite confused at what the results were telling me. I know they're meant to be all the same. The compression tester itself is a gunson one which i trust.
The reason i decided to do the compression test was because the mini didn't have any power under load, so this was the first of my trouble shooting. If anybody can offer me advice on what these results mean then i'd be very grateful.
Steve
Posted 12 March 2013 - 06:32 PM
Posted 12 March 2013 - 06:55 PM
Posted 12 March 2013 - 07:08 PM
Posted 12 March 2013 - 07:27 PM
any smoke ??
Posted 12 March 2013 - 07:28 PM
if you repeat the test. put thimble of oil down the bore before you start the test.
if the pressure shoots up then its just ware on the piston rings/ bore. if the pressure does not increase its a bad valve seat etc.
by adding a thimble of oil it should shoot up to over 200 psi
Edited by booton, 12 March 2013 - 07:32 PM.
Posted 12 March 2013 - 07:50 PM
Cylinder 1 - 185 psi
Cylinder 2 - 150
Cylinder 3 - 180
Cylinder 4 - 200
So from this my bores are worn, but also there could be a problem with the valves on cylinder 2?
Posted 12 March 2013 - 08:07 PM
By your results i think its just a worn engine, but not an HG fault.
Posted 12 March 2013 - 09:09 PM
Posted 12 March 2013 - 10:31 PM
AC
Posted 12 March 2013 - 10:55 PM
Posted 12 March 2013 - 11:04 PM
