Setting Tappets
alsy
, Mar 12 2013 01:43 AM
22 replies to this topic
#16
Posted 12 March 2013 - 02:59 PM
Metro 850 was 12 to 14 thou across the baord.
in fact a lot of Metro's where 12 to14 thou
And
Vanden plas UK 12 thou
MG1300 & VP Europe inlet 12 to 14 thou
exhaust 15 to 17 thou
MG turbo inlet 13 thou
exhaust 15 thou
Most standard Minis prior to about 1988 where 12 thou
And
exhaust 15 thou
#17
Posted 12 March 2013 - 03:07 PM
i just set inlet n outlet on my mpi on sat to 0.038mm, runs fine
#18
Posted 12 March 2013 - 03:09 PM
The bigger the gap the more wear you will have.
#19
Posted 12 March 2013 - 03:15 PM
Tru, but i think itll be fine
0.038 millimetres = 1.49606299 thou
#20
Posted 13 March 2013 - 01:12 AM
Thanks everyone, im going to be doing it tomorrow.. i have all day so il just check and check again, il let you know how i get on tomorrow night!
after reassurance to the question i asked yesterday, if the tappets are really far out will it cause the car to not even try to fire? because currently the car just turns over, and this is the only thing i can think that i havent done.
#21
Posted 13 March 2013 - 11:38 AM
If they are really far out then yes. or maybe o ne of them is really bad (or dropped a valve perhaps?)
Maybe check compression too if it's not firing
Edited by foggy, 13 March 2013 - 11:38 AM.
#22
Posted 13 March 2013 - 03:26 PM
Or if the nut runs itself all the way up off the stud so you have a completely loose rocker. (happened to my engine and it wouldn't fire easily and when it did it was missing,obviously) lol. It was fun re doing the clearances on the side of an a road! good job i always carry tools in my mini lol
#23
Posted 13 March 2013 - 04:23 PM
well i set the tappets today and it still wouldnt attempt to fire, i tried bumping it.. i had a fully charged battery and still nothing. ill get a compression tester tomorrow, say its all fine.. where else do i look :<
