Car Creeper And Mechanics Trolley
Posted 11 March 2013 - 09:21 PM
Some may have seen a question air i posted about this before!
I will post all the progress so far in one foul swoop and then update as I finish!
-Tom
Posted 11 March 2013 - 09:23 PM
Posted 11 March 2013 - 09:24 PM
Posted 11 March 2013 - 09:29 PM
Also, make the wheels lockable so I can use it too
Posted 11 March 2013 - 09:52 PM
I designed this in nov/dec and started manufacturing after Christmas. this is my progress so far,
A bit of background about the design and what to expect, the design in going to be foldable, so both a sitting and lying position are available, other features will include a tool tray and a heynes manual holder! so i can use both hands when fiddling with my mini, which will one day have a project thread in the mini section i hope!
To start with I cut 25mm squared steel tubing to the lengths I calculated (it took a while to get the right angles and heights)
Then I put it in a frame and tig welded it together
and drilled holes for the hinge mechanism
I then cut and welded on the sides of the hinge
Checked the alinement's
and checked it folded to 45 degrees
And it could support my weight in the sitting pos
Edited by M1N1 C00P3R, 11 March 2013 - 09:54 PM.
Posted 11 March 2013 - 09:57 PM
Good stuff, My first thing is, make it so its as low as possible, may sound ridiculous, but when using a creeper you do go up a bit, loosing space to undo those fiddly bolts!
Yep it may look like its going to be quite heigh, but with the wheels i intend to use (30mm high ball rollers) it shouldn't be more than 100mm tall padding included!
Posted 11 March 2013 - 10:01 PM
Add some small side trays for tools and parts!
one step ahead of you!
Here is my tool storage which i started today!
Simple fold and pop rivet 2mm aluminium!
Posted 11 March 2013 - 10:04 PM
Posted 11 March 2013 - 11:13 PM
Edited by M1N1 C00P3R, 11 March 2013 - 11:13 PM.
Posted 12 March 2013 - 11:26 AM
Posted 13 March 2013 - 05:31 PM
Posted 21 March 2013 - 09:00 PM
The tool storage finished
Attached a hinge for tool storage
cut out the boards for sitting on
Cut out the foam for the boards
covered them in vinyl that i brought
welded on a axle
and making a car manual holder (removable) so I have both hands for the car if necessary.
Thats if for now next update will be in 3 weeks or so due to holidays :). At the mo the frame is (hopefully) being powder coated ready for the attachment of wheels, seating, tool storage etc!
Thanks for reading!
Tom'
Edited by M1N1 C00P3R, 21 March 2013 - 09:04 PM.
Posted 26 March 2013 - 10:46 PM
Posted 27 March 2013 - 08:20 PM
I had the idea of fitting a row of high power LED lights along it too illuminate while working without torches.
