Posted 10 March 2013 - 11:21 AM
Hi Silvertoes,
I've managed to replace mine without removing much.
It is fiddly though. Here's how to do it - by the way, it is easier if you have the back of the car on ramps, you'll see why;
Put drivers seat forwards so it stays up. Don't lift the carpet yet.
Look down the side of the hand brake lever and locate the clevis pin - at the back end of the assembly. Pull out the split pin by bending the legs straight (pliers needed), then push out clevis pin. Look out for the washer on split pin side.
Lift carpet and unscrew plastic blanking plate over cable. Tie a bit of string through the bracket holes on the cable & attach it somewhere with a bit of slack so you can pull cable back in if it all pulls through underneath.
Go under the back of the car and release split pins from each wheel lever (where the cable meets the back brake assembly), push clevis pins out and release the cables by pulling them towards back of car - you'll see where the spring fits onto a backplate. Note how the cable goes through the gap between brake pipe & backplate for when you re-assemble.
You'll see why it's best to be on ramps now. the cable will only pull though to the central area of the subframe if the radius arms are taking some weight, otherwise the gap is too small. If the back of the car is safely supported on axle stands, you can use a jack to raise each side (under the shock absorber) enough to make a gap. Make a note of how the cable fits in the quadrants - you may need to widen the gap with a screwdriver to get the cable out.
Once you've got the cable out into the centre, you'll need to feed the new one through the front cable bracket - a triangular thing. If you've bought a complete front & rear cable, it's much easier, as you can skip this bit. The front cable needs pulling back through this bracket - undo a spring washer at the front of bracket first (thin screwdriver). Make enough of a loop with the cable in the bracket to feed the new cable through, before working backwards and re-assembling everything.
Fiddly, but not too complicated. No garage needed, but a safe pair of ramps / axle stands is useful. I have done this with the car half on the kerb, when I was thinner. Remember to unscrew the brake adjusting nuts on the cable before re-attaching it to the handbrake assembly as there won't be any slack & liberally grease everything.
Good luck!
MA
