Another Big One, '68 Hornet @ Mintec
51 replies to this topic
#16 SAL 821X
SAL 821X
  • 1,890 posts
Posted 18 March 2013 - 01:29 PM
Loving your work Tupers.
Fabricating skills one could only dream of.
#17 Tupers
Tupers
  • 4,142 posts
Posted 19 March 2013 - 10:18 PM
Awesome, awesome, awesome!
lovely work !
Thanks again guys, practise makes perfect and one day I'll be super awesome. :lol:
Seeing stuff like this makes me realise just how bad mine is gonna be O_O
It can't be that bad, have you seen the Crayford thread?
That would be cool! Not seen a spaceframed Hornet/Elf before. Turbo, yes! I think if I had one, I would make it look like a period racer, Cooper S spec engine. S wheels or period Vortz Racing Rose Petals, Surf Blue paint. Similar to this basically
Now that would look sweet!
Anyway sorry for clogging your thread up, great progress as always, really looking forward to seeing what you do with this
Max
Don't worry about it Max you're not clogging it up just adding more cool stuff. I'd much rather have that Hornet than a cooper to be honest.
So how's about a little more progress. After lots of measure and welding the Hornet now has a heel board and side closing panels.
I've also got 99% of the plug weld holes drilled in the flitches and they just need a little fettling before I weld them on.
The half floors with outer sills and jacking points arrived as well and the O/S floor is all but ready to weld in. Note in the pic bellow the floor is just clamped up from bellow for marking up.
#18 DAVEY_C
DAVEY_C
  • 555 posts
  • Local Club: irish minis owner club
Posted 19 March 2013 - 11:57 PM
nice project tupers, for the amount of work needed it'll be interesting to watch it progress :proud:
is there anywhere that sells rear body panels for hornets?
#19 mk1leg
mk1leg
  • 9,343 posts
Posted 20 March 2013 - 09:59 PM
Once again your work astounds me the detail is fantastic .......I have a hornet as my next project......its not been on the road for 30 years but it was garaged
its minus a few items no engine, no interior....but never mini it only cost £400..... :proud:
#20 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 21 March 2013 - 01:32 PM
looks like youve got a slightly easier project on your hands here.... :)
#21 Tupers
Tupers
  • 4,142 posts
Posted 23 March 2013 - 09:59 PM
Thanks Davey, it is a bit of an extensive one this. As far as I know nobody does rear panels for these it's all got to be fabricated.
Thanks Mark, it looks like yours is a little more complete than ours
He has hasn't he, maybe we should swap. :lol:
I've been dotting around on a few other Mintec projects since I last posted but I have now got both floor pans welded in.
Nice wide welds all the way down the tunnel, these wont be going anywhere in a hurry. ;D
#22 steven
steven
  • 1,195 posts
Posted 23 March 2013 - 10:01 PM
looks great
#23 Tupers
Tupers
  • 4,142 posts
Posted 27 March 2013 - 11:16 PM
looks great
Thanks Steven, it should only get better. :proud:
The rear bumper rails on the Hornet are rather knackered all the way around and the solid spots are suspiciously full for weld so I made a start on replacing them today.
I made a card template for the corners and then transferred it onto some nice fresh steel.
When it came to the rear section I folded a long length of steel and then ran it back and forth through the stretcher to achieve the right bow.
I also folded up a new end for the seat crossmember as the old one was plated and rather nasty.
And a lovely front panel conversion panel arrived in the post.
#24 Tupers
Tupers
  • 4,142 posts
Posted 11 April 2013 - 07:05 PM
Not a very good photo (it's in primer now so I'll get a better one) but the centre section of the bumper rail is now welded up and flushed in.
Sitting out in the rain had done some rather nasty things to the corners of the boot frame so after a bit of thinking on how to actually form the replacement sections I got the O/S replaced.
The N/S was a bit worse and took a little more time.
After folding two sections for the frame and running them through the shrinker/stretcher I clamped them together, trimmed and welded them together
I also made up the outer section and got everything clamped together, nearly there. :shy:
The salvaged door frame came back from blasting today as well so I stuck some more bracing in so I can chop the frame out tomorrow and get the new one welded in. :highfive:
#25 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 11 April 2013 - 07:38 PM
Nice Tupers very nice. :D
#26 Tupers
Tupers
  • 4,142 posts
Posted 14 April 2013 - 10:12 PM
With the bracing in place I was able to remove the A-pillar/post leaving only the windscreen frame in place.
I cut the replacement frame down leaving 20MM more than I needed at each end. It's better to leave it long and pair it down than cut it to where you think it should be straight away and find it too short. I also painted the inside of the frame and the other areas on the body that wont be accessible once everything's welded.
Here it is paired down a little more and bolted in. All that's needed now is to punch holes for plug welding and then final fitment can begin.
I also put a few good coats of primer on the bonnet, boot and doors that where also blasted.
The bottoms of both doors need attention as do both front corners of the bonnet but all in all they're not too bad.
#27 construction.mini
construction.mini
  • 56 posts
Posted 15 April 2013 - 01:07 PM
You Sir are my HERO!!!!! lol :shy: I need to weld mine up but im soooo scared of boging it. But you inspire my to try!!!!!
#28 Tupers
Tupers
  • 4,142 posts
Posted 15 April 2013 - 08:23 PM
Well I suppose everyone needs a hero, not sure if I'm really good candidate for one though. :lol:
The most important think is to just take you're time. Take a good look and how each repair will effect the other work around it and try to do it in an order that will simplify the next job.
I got stuck into the bonnet today while waiting for a second coat of paint on the door frame to dry.
I started out by marking how much of the original skin + repair I wanted to cut out.
A small section of steel was cut down to size and shaped to match the slight curve of the bonnet before being tacked in.
Then I welded both sides up and linshed them down, there's just a small amount of work left to be done with a panel hammer and spoon.
The A-pillar-post is also now officially in although I forgot to take picture of it welded as I was busy sweeping up so these pics of it pre welding will have to suffice. :shy:
#29 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 15 April 2013 - 08:33 PM
Excellent work Tupers :thumbsup:
#30 miniman267
miniman267
  • 452 posts
  • Local Club: mendip minis
Posted 15 April 2013 - 08:46 PM
Got to admit I am starting to like the hornets more and more
Also lovely bit of work defo professional
Edited by miniman267, 15 April 2013 - 08:47 PM.
