Posted 07 March 2013 - 10:47 PM
Is there a deffinitive guide to do this? Or is it in the haynes?
Posted 07 March 2013 - 10:52 PM
I can't remember whether that also exists on Verto flywheels as I always mark a TDC mark on the front pulley and timing cover or highlight the existing marking points on front pulley & timing cover with a bit of yellow paint.
Posted 07 March 2013 - 10:58 PM
Or you can go really old school and do it with a a screw driver, though not very accurate.
Posted 07 March 2013 - 11:00 PM
Posted 07 March 2013 - 11:03 PM
Seems very technical, can't I just hit it with a hammer or grind something off? I think I will have to get someone engine minded to help me
A DTI gauge really isn't a confusing item, I'd say its one of the most vital tools when engine building.
Watch the JanSpeed D.I.Y Mini Video on youtube, all will be explained in there, it's 4 parts. I will say for certain you'll have to watch it about 5 times. LOL.
Posted 07 March 2013 - 11:06 PM
A screwdriver down a plug hole will not be accurate enough. Do you have no markings on the front pulley with a small bracket on the timing cover?
The only other way to get it spot on is to take the head off and use a DTI on a piston crown, then make up a small bracket adjacent to the front pulley and mark TDC in light coloured paint.
Posted 07 March 2013 - 11:07 PM
Posted 07 March 2013 - 11:09 PM
Remove plug
Get screwdriver
Put screwdriver in home until you feel piston
Rotate crank until the screwdriver it at the top of its travel
This is TDC. You will need firing on no.1 cylinder TDC though. When the engine is as general TDC it's either on the firing stroke or the exhaust / intake stroke. For the engine to be on firin stroke both valves should be shut. This means the rockers will have no weight on them and they will be able to rock slightly
For firing on no1 cylinder and TDC, screwdriver at the top of travel, both rockers able to be rocked slightly
Hope this helps on cowboy mechanics! ;)
Posted 07 March 2013 - 11:10 PM
For what you are doing you do need it to be accurate +/- 1 degree.
On the Nodiz setup you have a big margin for adjustment, so it doesn't have to be absolutely bang ln
Posted 07 March 2013 - 11:15 PM
You do need an accurate TDC for timing in a cam, but then the head can be off so that you get it absolutely exact. I do like a reference point, but it's not vital.
Posted 07 March 2013 - 11:17 PM
I have heard of a DTi guage going down the spark plug hole though, means cam changes can be much faster
Posted 07 March 2013 - 11:25 PM
If its verto flywheel you will NOT be able to use the clutch cover and the "nib" as there isn't one fitted.
There are extra long DTI's I have one that is about 10" long, although these can be used on engines with the spark plugs above the centre of the piston, its not a good idea to use them on a Mini or similar as you will break it, and won't get an accurate measurement, you will be measuring piston position but won't be able to take into consideration piston rock.
You have yo measure above the gudgeon pin centre line.
Posted 07 March 2013 - 11:27 PM
How old are you?
(just taking a leaf out of DILLIGAFs book ;))
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
