Clutch Pedal Travel
Posted 07 March 2013 - 06:44 AM
Posted 07 March 2013 - 09:06 AM
Bob
Posted 07 March 2013 - 09:45 AM
It's almost like the movement ratio at the pedal vs. cylinder is wrong. Could the master cylinder be the problem?
Update: I added a new master cylinder to my Mini Spares order for good measure...
Edited by Woreign, 07 March 2013 - 11:11 AM.
Posted 07 March 2013 - 01:15 PM
Posted 07 March 2013 - 01:58 PM
Posted 07 March 2013 - 11:14 PM
If you reduce the clearances of those specified you run the risk of damaging your engine or clutch.
2 lengths of push rod to cylinder (not solenoid, as solenoids are electric) the longer pushrod is for an earlier clutch, I very much doubt if you have one of these as they didn't work very well and where changed in the early 60's
Posted 16 March 2013 - 09:18 AM
Posted 19 March 2013 - 11:51 AM
I checked the plunger, and there is some play within the hole and the ball of the lever. Not a lot, but maybe too much? What is an acceptable amount?
The only problem is shifting into first when it will occasionally crunch. 2nd, 3rd, and 4th are fine.
Edited by Woreign, 19 March 2013 - 11:53 AM.
Posted 19 March 2013 - 11:56 AM
if its only a problem in 1st gear with a crunch are you sure its not the bulk ring worn on 1st gear
Posted 19 March 2013 - 06:20 PM
When you let up on the clutch pedal, does the plunger within the slave cylinder retract away from the end of the clutch rod? I wonder if that's my problem?
Posted 22 March 2013 - 09:06 AM
