I'm wondering what the normal operating oil pressure should be? When cold, my oil pressure gauge reads a little over 50psi. As the engine warms up, it drops down to around 30 at idle and 40-45 when driving. Just wondering if this is normal?
2 replies to this topic
Posted 07 March 2013 - 06:39 AM
Posted 07 March 2013 - 07:55 AM
Sounds pretty good... Your running oil pressure is governed by the oil pressure relief valve, and your idle oil pressure is indicative of big end/main bearing conditions.
Posted 08 March 2013 - 06:26 PM
Yes, not too bad, however my newly rebuilt engine will run at a little higher pressure.
The pressure should drop on a warm engine at idle as the oil is thinner when hot, and so less pressure required to force it around the passage ways in the bearings etc.
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
