Twini Mini
Posted 04 March 2013 - 10:19 PM
Posted 04 March 2013 - 10:25 PM
The way John Cooper did it in the 60s was modify the rear of his car to accept a front subframe in the back, and it worked well until one of the rear hubs became un secured and ended up totalling his car at a great speed (cant remember how fast but it was a big crash).
you could use the same system, but it would take a lot of engineering to do it legally and safely, If it was me I would use a fly by wire system for throttle controls as that will allow better synchronisation, the gear stick mechanisms would need a bit of thought as I cant instantly think of a way to get it to change gear at the same time for both engines
Posted 04 March 2013 - 10:26 PM
It's not easy, but there is a lot of info about it out there if you know where to look.
Posted 04 March 2013 - 10:29 PM
Wouldn't be too hard, and would be very very awsome!
Be easier to modify the diff housing to allow a prop shaft to come off it, as special tuning did. They did produce a 4wd A series set up, was fitted to the Austin ant. Very limited production!
There was a man on another forum (moke possibly) who was re engineering a 4wd BMC diff looked like a good project
Edited by Alex_B, 04 March 2013 - 10:30 PM.
Posted 04 March 2013 - 10:31 PM
Synchronising two engines is very tricky and If you want it to be road legal I dont think you can legally run two engines at once.
do you have any pics of the car before or after the crash by any chance
Posted 04 March 2013 - 10:34 PM
I have an idea in my head where you could use two manual engines, as they are both in the same orientation, you could have the engine in the rear have the gear stick come below the engine, using a rose jointed lever, but tweaking it so it operates with the other gear stick correctly would be tricky
yes i thought that a similar setup to what is used on the gtm coupe and blast 2 ithink its called kit car bent bar basically goes under the gear box
and a 4wd a series sounds mint anyone got pics of it and if you guessed already i like pics
John coopers twini mini came about if i remember correctly because he wanted one after helping design a couple of Twini Mokes which were planned for the army as the 2wd moke was a flop in their eyes :)
Posted 04 March 2013 - 10:36 PM
Posted 04 March 2013 - 10:44 PM
I still think a 4WD a series will be better though! Il get some pics tomorrow, I'm sure I saved some
Posted 04 March 2013 - 10:46 PM
Posted 04 March 2013 - 11:15 PM
Nope, it's going to be expensive!
thanks for that mate would be great if you got some and would be interesting to see if i would the able to machine a new 4wd diff at college
thanks british racing green it looks good but not keen on the nitrous
I would be a great fun engineering project but it will be very expensive, If it was me I wouldn't look to do it unless I could do it for fun and not be worried about money
yeah would be a great project and be nice to take round the shows and have took many minis aprt over the years so got plenty of parts and would be able to get rest of the metal from work and then machine it at college
Posted 04 March 2013 - 11:17 PM
