Mk2 Rear Lights On A Later Mini?
Posted 02 March 2013 - 05:01 PM
I apologise if this has been asked before but I spent about half an hour searching for a thread with no luck.
My question is, is it possible to fit the Mk2 rear lights with no reverse light onto a later (1988 ish) Mini?
Would it leave a massive hole where the old, bigger light was?
If this has been asked before, I would appreciate it if you could point me in the direction of the thead.
Many thanks
Harry
Posted 02 March 2013 - 05:07 PM
Posted 02 March 2013 - 05:09 PM
you may have a mark in the paint around the edge of the gasket though as the mk2 gasket is smaller than the mk 4 one
Posted 02 March 2013 - 05:12 PM
That's exactly what I wanted to hear!
It won't be a problem fiddling with the wiring as I am pretty competent on the electrical side of things.
Alex, that shouldn't be a problem as I am intending to do an entire respray as soon as I have the funds available.
Now I just need to decide whether or not to put a reverse light on.
Thanks for the help guys.
Harry
Posted 02 March 2013 - 05:16 PM
I found it best to do one side and a time so you can check where the correct cable positioning do want to going wrong
Hope this helps
Posted 02 March 2013 - 05:37 PM
Posted 02 March 2013 - 06:03 PM
Sorry but that sounds like a classic case of bodgery being far more work than doing something properly! Either converting the loom to the original Mk2 termination or buying a pair of 4-way church window connectors to convert the lamps to Mk4 termination would be far simpler and would leave you with a pair of functioning lamps to sell.
Yeah I know but I'm not very good with electrics
Posted 08 September 2015 - 03:26 PM
sorry to dig up an old thread but will the light lens covers simply screw on to mk4 units?
Posted 08 September 2015 - 03:41 PM
Nope, the mk2 light lenses are smaller than the mk4 lights. You need to change the whole unit
Edited by megamini_jb, 08 September 2015 - 03:42 PM.
