The car is fitted with a Mini Spares 4 pot calliper on vented disc setup.
They don't fit. The top and bottom edge of the callipers contact the wheel. I need an additional 3-4 mm of clearance.
I was assured the would fit when I asked.
What do I do now?
a) fit a 5mm spacer?
b) grind some metal of the edges of the calliper untill I have enough clearance?
c) fit 3mm spacers and maybe grind the callipers oh so slightly?
