Twin Fuel Tanks?
32 replies to this topic
#31 Jase
Jase
  • 1,166 posts
Posted 19 July 2013 - 02:42 PM
I've just fitted mine:
a) Because they look cool with the twin filler caps (expensive aesthetic).
b) I'm going to fit twin SU's.
c) I don't have to fill up so often.
d) Did I say they look cool :)
#32 mab01uk
mab01uk
  • 12,412 posts
Posted 19 July 2013 - 06:05 PM
Properly set up twin SU's should not increase the fuel consumption........
if you only want the aesthetics you can fit a dummy RH tank filler neck like this:-
http://www.minispare...im/MSA1126.aspx
DUMMY RIGHT HAND TANK NECK KIT
"The "S" Look. If you want the look and not the cost this is your answer. This fake filler neck comes with it's own blind grommet, the assembly is held on with two screws or rivets. Once installed it looks genuine."
Edited by mab01uk, 19 July 2013 - 06:08 PM.
#33 Jase
Jase
  • 1,166 posts
Posted 19 July 2013 - 06:45 PM
I will probably add a few extras as well to increase performance :)
""The "S" Look. If you want the look and not the cost this is your answer. This fake filler neck comes with it's own blind grommet, the assembly is held on with two screws or rivets. Once installed it looks genuine."
Then it would be fake, not into that. If your going to do it it needs to be done properly!
