Twin Fuel Tanks?
32 replies to this topic
#1 Ado1379
Ado1379
  • 588 posts
Posted 01 March 2013 - 08:22 PM
i was wondering how much it costs roughly, and if its worth doing? if anybody has done id be a happy man if i could see some pics ;) cheers people :)
#2 944turbo
944turbo
  • 75 posts
Posted 01 March 2013 - 09:35 PM
Hi well worth doing if you ask me did my sons looks the dogs,looks a lot better though if you can obtain an early 5gal left hand tank as well.Costing came out at about £400 for me with the boot board but was very lucky in obtaining a right hand tank at the right price,here is a picture if this helps.
  • Attached File  012.jpg   37.28K   192 downloads
#3 Sfuller1275gt
Sfuller1275gt
  • 296 posts
  • Local Club: Lsmoc
Posted 01 March 2013 - 09:39 PM
Neat nice job
#4 Cooperman
  • 23,276 posts
Posted 03 March 2013 - 12:48 PM
With the 5.5 gallon original tank, range with a 1275 'S' was poor even on a standard car doing around 30 mpg, and in competition it was hopeless.
Even with a 7.5 gallon later tank a modified Mini giving, say, 27 mpg the range was poor.
So yes, a RH tank is very useful if you are doing longer journeys in a 1275 at fairly high cruising speeds, or driving quickly in the lanes in low gears a lot of the time. There are also far fewer petrol stations now than there were in the 60's.
#5 Sfuller1275gt
Sfuller1275gt
  • 296 posts
  • Local Club: Lsmoc
Posted 03 March 2013 - 03:14 PM
So copper man what sort of range can you get out of a 7.5 tank I havnt driven a mini for 12 years now petrol prices were obviously alot different then how to fill the tank and what's the range I have now got a 1380 so what do u rekon 25mpg ??
#6 Cooperman
  • 23,276 posts
Posted 03 March 2013 - 03:36 PM
With a 1380 and depending a bit on overall gearing, you should get maybe 30 mpg on a main road journey. Allowing a sensible reserve that is about 180 mile safe range which is fine for a classic car used as a second or 3rd car, but for more regular use it's a bit short on range.
On a rally in my 1310 cc 'S' I have 11 gallons (twin 5.5 tanks) and my useable range is 140 miles or thereabouts.
The Mini is not the only classic with what is now seen as low tank capacity. For example, the Mk.1 Lotus-Cortina had, from memory, 8 gallons. There used to be lots of petrol stations, a lot open all night, back in the 60's so short range was not an issue.
#7 Wigeon Incognito
Wigeon Incognito
  • 294 posts
  • Local Club: Essex Mini Club
Well if you get about 25mpg then just multiply that by your tank size in gallons so 187.5 miles for a 7.5 gallon tank.
#8 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 03 March 2013 - 05:04 PM
i got my rright hand tank from australia, made by a guy called paul gulson, it worked out cheaper to buy it and ship it in than buying one in this country
this is his ebay account thing http://myworld.ebay.co.uk/gulsonpower/
and an advert about his tanks
https://www.dragtimes.com/parts/RH-FUEL-TANK--COOPER-S-MORRISMINIROVER-RILEY-ELF_140537801081.html
YetI
#9 mk1leg
mk1leg
  • 9,343 posts
Posted 03 March 2013 - 09:18 PM
you will also need a tank fitting kit thats the under tank stand and the strap bracket that fits to the rear of back seat........
#10 Ado1379
Ado1379
  • 588 posts
Posted 14 March 2013 - 04:28 PM
i might have to do this at some point! i think they look pretty cool as well. thanks guys great help!!
#11 Jase
Jase
  • 1,166 posts
Posted 18 July 2013 - 03:29 PM
Does the bottom short bracket then just simply bolt to the floor?
#12 jpw1275
jpw1275
  • 2,803 posts
Posted 18 July 2013 - 05:21 PM
there welded buddy like the left side
#13 mk1leg
mk1leg
  • 9,343 posts
Posted 18 July 2013 - 08:05 PM
I pop rivetted mine as per optional extra in the 60s......but yes you can weld them in......... :highfive:
#14 Jase
Jase
  • 1,166 posts
Posted 18 July 2013 - 09:18 PM
Still a bit confused, I have welded  the bottom bracket but have a spare nut and bolt with a hole going through the short bracket. I have the minispares kit:
Excuse the seam sealer:
#15 Jase
Jase
  • 1,166 posts
Posted 18 July 2013 - 09:28 PM
Just looking at your second picture, the short strap which is bolted to the longer one, is this bolted to the floor as well?
I've never seen a R/H tank installed in a car before and assumed I would have had instructions with the kit.
