Wind-Up Window Seals/runners
Posted 26 February 2013 - 08:57 AM
Having spent a day fighting to remove the old seals PAM3076/7 I have a question, should the new seal be glued into the channel or does the window just hold them in place...?
Thanks again for your help!
Posted 26 February 2013 - 09:16 AM
I was actually surprised by how easy they were to fit. I expected to have to use clips or glue like on other cars.
Posted 26 February 2013 - 09:17 AM
Posted 26 February 2013 - 09:25 AM
The old ones were glued at the two ends inside the doors - a nightmare to remove if you are not a gynaecologist!
Still, done now and new ones going in....
Posted 26 February 2013 - 11:34 AM
Posted 18 August 2013 - 10:18 PM
Going to jump on the back of this one if i may???
Tried fitting my new seals today and struggled like chuff..!!
Question
Do you have to take the glass out to fit the seals? I'm guessing so as i struggled 80% of it flew in then last section could not get into door cavity??
Advice please?
Thanks in advance
Posted 19 August 2013 - 06:11 AM
Question
Advice please?
Thanks in advance
Yes, you need the window out to fit the seals...
