Any Tips For Honing An Engine
Posted 25 February 2013 - 09:09 PM
Just been out in the bitter cold to measure up all my bores in my 998 and they are all still with tolerance with regards to the haynes but the bores are very glazed. So i was going to rehone and get some new rings.
I've got one of the tools that fits in a drill and i get the theory of creating an up and down movement while rotating slowly.
Any other tips?
Posted 25 February 2013 - 09:25 PM
Posted 25 February 2013 - 09:29 PM
I have to say that I have done that with mine and so far it looks fine, (after initial fire up). Can't show you any before and after pics because photobucket is down at the mo. If there are no major gouges on the bores or ridges then all should be fine in my opinion, but I am no engine building expert lol.
If you could put up some pics of the bore condition it will help the experts' opinions. Also how many measurements of the bores did you do as they need to be measured by internal gauges in many places to ensure they are indeed the correct shape through the entire length.
Will put some pics up later if I can.
Graham
Posted 25 February 2013 - 09:37 PM
Some will tell you otherwise. Including some "experts".
But put it this way. Professional shops will spend thoudands on machine to do this. They wouldnt bother if you could do it with a 20 quid tool and a hand drill.
Posted 25 February 2013 - 10:28 PM
Posted 25 February 2013 - 10:33 PM
Posted 25 February 2013 - 10:35 PM
Posted 25 February 2013 - 11:41 PM
Of course, worn bores require re-boring, final honing and new pistons at the next size up.
Posted 25 February 2013 - 11:43 PM
I use bore gauges when I do rebores and I use calibrated setting rings, a set like tis would normally retail at about £1700 and would need to be accurate and repeatable to 0.002mm or 0.0001"
A reasonably decent bore honing machine will cost anywhere from £5000 second hand upto £50+K
I would never use the glaze busters as they are NOT hones, they will follow whatever the cylinder is now shaped like, be it oval, tapered or possibly even hexagonal..
A proper Honing machine is designed to take out materialand make the bored cylinder round, irrespective of what mess the boring machine does, it will also take out tapers, the glaze buster will not.
Glaze busters if used incorrectly can also be a little bit dangerous, they should NOT be spun at high speed, 100 to 300 rpm being about maximum RPM.
Posted 26 February 2013 - 07:11 AM
Posted 26 February 2013 - 07:45 AM
Posted 26 February 2013 - 09:31 AM
With a well-worn engine the only solution is a re-bore and new pistons. In fact it is not unusual to spend money on keeping a classic car on the road and re-building is part of classic car preservation, the money spent being a part of the steady increase in value over the years, which we have seen with all classics, especially the Mini.
Posted 26 February 2013 - 09:32 AM
If as you say the lip is 0.01mm per side and the cylinder is not worn more than this then you may be able to hone it out to size, however, I can't think of anyone I know with a Honing machine that would bother, this has a lot to do with how it will wear the stones as well as the potential for failure, it just may not clean up, then its down to their reputation....
I think you have 3 choices, get a bike, bore and new oversize pistons or another engine
Whilst choice 1 will keep/help make you fit, hopefully its working on me anyway
Choice 3 is an unknown and you may well find yourself in the same situation
Choice 2 is the best except on cost as it will cost you a few pennies...
Posted 26 February 2013 - 09:36 AM
I'm sure the older peeps on here remember them? Piston rings intended to cobble together old engines. The top ring actually had a step in it to avoid the ridge left by a worn bore!!
Happy memories!!
Posted 26 February 2013 - 09:47 AM
Its time like this I miss 'cord' ridge hopper piston rings???!!!
Happy memories!!
I remember them well, Shifty, although I never used any, not even on my old Ford V8 Pilot.
They were a real 'bodge' although a lot of 'engine re-builders' used them. But people still ask "How cheaply can you build me an engine?" The answer is that it's not possible to build a cheap engine and gget a good result. I look at some of the prices for re-built engines 'on exchange' and wonder at how few man-hours have been spent doing them. Thorough and accurate build quality -if you like!
I don't know what others have experienced, but it seems to me that over 50% of those who put 2nd habd un-tested engines into their cars end up with big problems after a short while.
Old engines, like the Mini engine, don't last like modern engines and with classic cars engine re-building to a good standard is necessary.
