Effect Of Changing Rear Wheel Cylinder Size?
30 replies to this topic
#1 mailman
mailman
  • 222 posts
Posted 25 February 2013 - 06:59 PM
Hi,
I know that there is information around here somewhere but for the life of me I haven't been able to find it.
I'm very confused as I seem to have read in the Haynes manual that an increase in bore size increases pressure, and in an article on Minispares it suggests the opposite (which seems more likely to me).
Can anyone clarify for me the effect of changing wheel cylinder bore size?
And with that, to provide the best balance with my new 7.5" disc set up, should I replace my rear wheel cylinders with 9/16" (standard), 11/16" (as per the article on Minispares), or 3/4"?
#2 MRA
MRA
  • 7,607 posts
Posted 25 February 2013 - 07:20 PM
Think of it like this.... 2 people each 100kg get in a lift of mass 500kg the total force is now 700kg now at the next stop 5more people each with a mass of 100kg get in the lift assuming no one leaves, you now have 1200kg total mass
at the next floor the lift suddenly double in area allowing another 7 people each with a mass of 100kg to enter the force is now 1900kg
does that help ?
#3 mailman
mailman
  • 222 posts
Posted 25 February 2013 - 07:27 PM
I think it does. But in simple terms, are you saying that larger cylinder equals more braking pressure on shoe?
#4 midridge2
midridge2
  • 1,794 posts
Posted 25 February 2013 - 07:31 PM
I think it means its a magic lift. lol
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 25 February 2013 - 07:40 PM
I've no idea on the physics, but I switched from drums all round to 7.5 discs, I've got the 3/4" cylinders on the rear. Works a treat non servo.
Most of braking is done by the fronts anyway...
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 February 2013 - 07:56 PM
Yes - larger bore = more force applied to the shoes. But problem with Mini is TOO MUCH braking force on the rear wheels.....causing nasty spins.... My advice - fit the smallest cylinders, throw away the horrible taper nose 'pressure regulator' and fit instead the original 'pressure limiter' in the line to the rear brakes (put it up on the bulkhead near / just below the master cylinder) - and you can then fine tune the max hydraulic pressure going to the rear cylinders by modifying the spring . It works - and yes - no servo - and no more spins !
#7 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 25 February 2013 - 07:59 PM
larger cylinders (or calipers) means more force, BUT more travel on the pedal.
#8 Cooperman
  • 23,278 posts
Posted 25 February 2013 - 08:22 PM
Very good advice, Roy.
#9 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 25 February 2013 - 08:55 PM
I've been told (with my alloy minisport calipers) to fit tiny 1/2" rear cylinders. So I have a new pair ready to fit. I'm using a non servo yellow tag MC and a Wilwood brake bias valve (adjustable) on the rear line, mounted beside my seat.
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 25 February 2013 - 09:12 PM
Is this a road car? Or a car that has to see road use? Having the brake bias adjustable from the driver's seat is very much illegal.
#11 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 25 February 2013 - 09:38 PM
With smaller RWC will give you a higher firmer pedal. This feel is often found to be more agreeable to the driver as the brakes feel right there.
I like the 1275 gt rwc.
#12 MRA
MRA
  • 7,607 posts
Posted 25 February 2013 - 11:24 PM
Yes the bigger the CSA (Cross Sectional Area) of the pistons CSA * Quantity the more force acting on the brake pad or shoe, however the larger the CSA the lower the displacement, hence why in certain circumstances it can be very dangerous and lead to double pumping of the pedal..
The opposite applies to the master cylinder.
#13 MRA
MRA
  • 7,607 posts
Posted 25 February 2013 - 11:25 PM
You dear Sir are a p*** taker of the 1st degree :-)
#14 mailman
mailman
  • 222 posts
Posted 26 February 2013 - 04:14 AM
Some very, very useful information here. My plan is to re-route the brake lines when the engine is next out. Currently I have the standard (and original) diagonal split system.
If I can, can I ask for some really specific advice, I have the minispares 7.5" disc conversion with 4-Pot calipers. The original RWC's were/are 9/16", I was under the impression that I needed to change the size of the RWC to correct the pressure.
Is the thought behind this that I should increase the pressure at the rear to match the force at the front? Or, to decrease the pressure at the rear to counteract a greater pedal force applied? I seem to be wrapping my head around what the size changes do, now I'm not sure why and which way to go. The later ones were as big as 3/4" with discs etc. Why?
#15 mailman
mailman
  • 222 posts
Posted 26 February 2013 - 06:11 AM
Foolishly forgot to include the specific information that I was after
If I can, can I ask for some really specific advice, I have the minispares 7.5" disc conversion with 4-Pot calipers. The original RWC's were/are 9/16", I was under the impression that I needed to change the size of the RWC to correct the pressure. Which RWC would be best, i.e. performance and safety.
