V-Twin Mini (Version 2.0)
roundnose
48 replies to this topic
#31 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 07 April 2013 - 12:13 PM
Throttle cable's gonna be pretty long!
Short compared to a lot of stuff, even stuff like 911s would be significantly longer. Then think about something like a VW type 2, the cable is nearly 1 1/2 times as long as a mini! As for rear engined buses............
#32 darkcat
darkcat
  • 398 posts
Posted 08 April 2013 - 07:53 PM
Not in work today, so got a good few jobs done.
Ripped apart the spare old front subframe, cleaned all parts etc and built up the new rear front subframe, figured out a front mounting system for it, and fitted a temporary upper mount bar (until i get the roll cage started)
And built up the other 2 swivel hubs with all new ball joints, seals and bearings.
#33 zuluaga63
zuluaga63
  • 113 posts
Posted 08 April 2013 - 08:14 PM
whaaat ! i want a fiver glass mini !!
#34 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 09 April 2013 - 11:57 AM
looking forward to this build!
#35 darkcat
darkcat
  • 398 posts
Posted 19 April 2013 - 02:25 PM
Engine mounted :-) (the front mounts will be revised once the cage is in)
#36 darkcat
darkcat
  • 398 posts
Posted 03 May 2013 - 07:12 AM
And finally!
My Diff is complete.
I am running a standard mini diff open, lubed with dry chain lube - This is not a track car and i dont expect to be spinning up one wheel a lot so should do the job nicely - I could always swap it for a sealed quaif later on if it proves problematic.
This would have happened quicker, however drilling hardened steel is impossible, so i had to get it spark-eroded.
#37 dribble
dribble
  • 386 posts
Posted 03 May 2013 - 10:48 AM
keep up the good work dude. ;)
#38 darkcat
darkcat
  • 398 posts
Posted 06 May 2013 - 12:38 PM
Drum roll.....
engine / diff / rear subframe complete :-)
#39 Willy_sa
Willy_sa
  • 93 posts
  • Local Club: MOCSA
Posted 06 May 2013 - 12:41 PM
That looks great!
#40 Camshaft1982
Camshaft1982
  • 60 posts
Posted 06 May 2013 - 02:40 PM
Nice work. That is going to be a lot of fun to drive.
Having a front subframe in the rear is going to make alignment adjustments rather easy as well.
#41 seancv1
seancv1
  • 187 posts
Posted 09 June 2013 - 09:30 AM
Looking good just waiting on an update !
#42 darkcat
darkcat
  • 398 posts
Posted 10 June 2013 - 05:27 PM
Its on hold a bit while a rebuild my daily mini's engine, nearly done  :-)
#43 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 06 October 2013 - 03:05 PM
Hi, sorry if I've missed it... Where did you get the shell from? My dad is looking for one just like this
#44 darkcat
darkcat
  • 398 posts
Posted 26 November 2013 - 10:06 PM
AND I'M BACK IN THE ROOM!
so the daily mini took a LOT more work than i thought.
anyhoo, now im back on the plastic one :-)
more to follow............................
#45 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 27 November 2013 - 12:13 AM
Seem to have missed this, an interesting project!
One thing I can't help but think though, isn't having the engine mounted above the crownwheel going to put the centre of gravity quite high?
