Triumph Rocket Engine
6 replies to this topic
#1 muzzal 1275
muzzal 1275
  • 131 posts
Posted 22 February 2013 - 01:56 PM
hi all
ive just come by a triumph rocket engine and was wondering about
a possable mini engine conversion
the engine is a 2.3l, 3 cylinder motor that is shaft driven
just wondered that peoples opinions on this are ?
thanks josh
#2 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 22 February 2013 - 02:10 PM
Anything is possible!
I considered this a dream choice for a bike engine conversion, given the size of it you'll probably be looking at a clubman front and maybe even extending it.
I'd be all over doing it, RWD it too ;-)
#3 Algordo1100
Algordo1100
  • 774 posts
Posted 22 February 2013 - 02:13 PM
140 bhp and 150ft/lb of torque should be entertaining, but It looks like it would prove a challenge to fit. Assuming an FF layout.
Its fitted into the bike longitudinally and I doubt it would fit that way in a mini engine bay, so you would have to modify the bay or turn it round through 90degs.
That might have an advantage in that the drive shaft would now be in the same orientation as the mini's front wheels. There would then have to be a diff unit for the front wheels that could be transfered power from the shortened drive shaft, or something. This transfer would also have to sort out the correct ratio.
I can imagine it being one massive project!
but anything is possible
#4 psychobob
psychobob
  • 205 posts
Posted 22 February 2013 - 03:04 PM
please try. it sounds mental!
#5 muzzal 1275
muzzal 1275
  • 131 posts
Posted 22 February 2013 - 03:18 PM
i have been toying with the idea for a while
now but as previously mentioned it sounds like
alot of work however before i give up on the dream
i shall measure for clearance to see if fitting it longitudinally
is an option
(you know when you sit there looking at it and you keep telling yourself it looks
like a good fit)
thanks for the replies
Josh
#6 muzzal 1275
muzzal 1275
  • 131 posts
Posted 22 February 2013 - 03:39 PM
the motor itself is quite compact and yes the original plan was
for rwd but i have always been concerned about how twitchy a rwd mini would be
due to its short wheelbase
#7 OfMini&Men
OfMini&Men
  • 284 posts
Posted 22 February 2013 - 03:43 PM
if your got the engine and a spare box. Drop it on top and see what you have to work with. .
anything is possible but its time and money.
