I don't think they're available anymore.
Front Bearings Worn
joss
, Feb 20 2013 05:47 PM
20 replies to this topic
#16
Posted 30 March 2013 - 11:56 AM
#17
Posted 30 March 2013 - 05:37 PM
Hi I know its a KAD part you get 4 poly rings and tie wire the kit cost £10 let me look in my blogs and get back
#19
Posted 30 March 2013 - 05:48 PM
here it is http://www.minisport...KAD1012230.html
I think he was asking about the oil seal spacer in the hubs, that appears to be a steering rack limiter kit.
#20
Posted 31 March 2013 - 10:57 AM
You are correct, I was looking for the oil seal spacer. I will have to take a look when I get the hub apart to see if theres ine in there.
I am getting a loud knocking on right hand corners from the N/S front wheel, I am going to investiate further tomorrow.......
Edited by cptkirk, 31 March 2013 - 10:59 AM.
#21
Posted 31 March 2013 - 04:58 PM
squeeking from th efront is more often going to be the bearing moving on the CV, a strip and check will tell you, if you have a worn groove on the CV or loose outer bearings in the hub.
You will need to replace all or any worn parts, then fit the new parts together using a large flat washer to "pull it all up" then fit the lightly greased cone washer..
The spacer in the rear (inner) of the hub is there to position the inner seal but careful fitment can eliminate the requirement, just fit it flush with the end of the bore as it changes to a taper.
Not fitting but also getting the seal incorrectly fitted will have nothing to do with the wear, and in all probability the "bearing" would still function as a bearing, except that now it will be loose on the new CV and cause damage.
Hence why every time you tighten it up within a short time it will come loose, this is also often seen by rusty dusty deposits around the CV nut and cone washer.
The cause is that it has NOT been seated correctly
