oil route in an A-Series
16 replies to this topic
#16 Ethel
  • 25,919 posts
Posted 30 September 2007 - 06:45 PM
where are the drain holes, there's a gallery evident on a 1275 'n obviosly the small bore blocks have the tappet chest. I thought maybe over the fuel pump or dizzy drives on the cam but theres no exterior evidence.
#17 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 30 September 2007 - 07:00 PM
Not from the outside, but you can see it from the sump
There are two holes, one between cyinders 1/2 and the other between 3/4. there isnt one between cylinders 2/3 because the canter main bearing and cam bearings are there and is rather a structural area of the block
You can also see it here, see pic---->
