Megajolt System What Does It Do
Posted 13 February 2013 - 11:33 PM
What does it do for the engine ?
Can you performance map it ?
Does it improve performance if so how much ?
Disadvantages ??
Posted 14 February 2013 - 12:46 AM
If converting from a points ignition you also have the benefits of the extra power of an electronic system, and zero maintenance.
There's not really such a thing as a performance map when it comes to mappable ignition, as by its very nature it should be optimum at all times once correctly set up, and therefore can't be improved upon.
The amount of performance benefit when changing from a mechanical system depends entirely on how wrong the old system was to start with. If, by some miracle the vacuum dizzy was giving exactly what the engine needed anyway then no change in performance would occur as nothing was wrong to start with.
On the other end of the spectrum you may have modified your engine and been told to use a non vac dizzy. In which case you will gain a large amount of power and response in the part throttle ranges atleast, and also big improvements in economy.
The engine will also run cooler and quieter with less exhaust boom and induction noise as the engine is not working so hard for any given speed.
The only disadvantges i would say are that if it breaks you cant necessarily fix it as easily on the side of the road.
Hope this helps
Tim.
Posted 14 February 2013 - 01:02 AM
Pro's, bin the conventional coil & distributor set up so you shouldn't have any problems with worn out points, fewer damp related problems when driving in the rain, you can virtually eliminate flat spots caused by too advanced or retarded ignition that you normally wouldn't be able to do with the conventional distributor & it can look neat and tidy under the bonnet.
Con's, can be a fairly expensive conversion & unless you understand ignition curves, can be a bit tricky to get the settings right without havin it set up on a rolling road, having said that, there's plenty of maps available on the like of the Autosport Labs website which should roughly give you what you need map wise.
I found when I converted mine to Megajolt, even with a sort of generic map downloaded from the ASL forum, the 1800 rpm flat spot I had under partial throttle disappeared and it's much more drivable.
There's plenty of info about it on the forum to.
Here's what mine looks like when finished
Posted 14 February 2013 - 03:04 AM
Posted 14 February 2013 - 05:42 AM
Posted 14 February 2013 - 07:50 AM
I have a group buy going on for a new system which is much improved than the megajolt and has a lot more features than the megajolt. head over to the mini chat and look for 'nodiz group buy'.
it will tell you everything
Posted 14 February 2013 - 03:05 PM
megajolt is for carb mini's, for injection you want the megasquirt.
Ahhh right thanks for that,I unfortunately cant afford it at the moment as i have a project mini to do, but as soon as thats done im doing a 850 engine based project to see how much mpg i can get out of a A-series (stage 1 kits & dtm exhausts are dated in my opinion), so efficency is the way im going.
Was thinking of using a spi/mpi head & manifold setup for the ecu to plug into (for the sensors & what not) as it injection theres less wastege think someone mentioned on here.
Is there any other ecu bases to use other than megasquirt ?
Thankyou.
Posted 14 February 2013 - 06:05 PM
Posted 14 February 2013 - 08:27 PM
in the same way you can fit a 'proper' dizzy to an spi and leave the ecu to control fueling. . I cant see why you couldnt fit a megajolt to give you programmable ignition...Cn this system be used on injection minis also or is megajolt carb specified ?
Posted 14 February 2013 - 08:29 PM
Posted 14 February 2013 - 08:48 PM
Posted 14 February 2013 - 10:06 PM
