Brace Bars (Different Designs)
#31
Posted 16 February 2013 - 11:44 PM
the only question that they can't all agree on is what bits of a mini are it's monocoque, the front panel and wings seem ok to remove but it seems like they want the inner wings or at least most of them in place
bulkhead mods are a no no 100%
#32
Posted 17 February 2013 - 12:04 AM
#33
Posted 17 February 2013 - 03:51 AM
Well there it is ay in black and white I would say that more than 50% of the inner wing still remains when the floppy bit is removed. More than 50% is legally most of the panel thanks for the info bugle I feel good now knowing my car is 100% legal with its remaining inner wings. There is no strength issue and now by your own admission whether you wanted to or not there is no longer a identity issue, or is that just how YOU see that bit black and white text to be?the front panel and wings seem ok to remove but it seems like they want the inner wings or at least most of them
#34
Posted 17 February 2013 - 10:05 AM
TheMat of a previous topic posted he did his vauxhal conversion the right way and informed the DVLA of his mods, there is more than 50% of his inner wings still in place and might be able to give you a more accurate percentage
have you run your 50% removal past them ?
#35
Posted 17 February 2013 - 10:09 AM
if strength is nothing to do with it then hows it apply to the monocoque which is all about strength most of the inner wings are retained as they start at the door hinge mounts also the teardrops mounts are on the front panel and are then tied into the inner wing so that makes no sense again this is down to your opinion of the minis monocoque not fact as no one nows which is the point im trying to make if no one knows the you dont so how can you give advice on it
the DVLA are only worried about the vehicles identity, is this car still a mini or a home made hybrid
but what you put back in the way of strength will effect the MOT
#36
Posted 17 February 2013 - 10:55 AM
It would be good to get a figure of how much is left by working out the sqr inch surface of a full inner wing and then the same of a cut down one to really see the difference that way we could really put the issue to bed so to speak.you might say 50% but the question is would the DVLA ?
Can anybody out there help with this by working out the surface area of a full inner wing panel?
#37
Posted 17 February 2013 - 11:16 AM
I think youll find iva's have more to do with vosa than the dvla....
#38
Posted 17 February 2013 - 11:18 AM
Ooossshhhh good shot there right in the mangina lol
#39
Posted 17 February 2013 - 11:25 AM
Personaly i didnt fit any before when my mini was last on the road... Ill be making some tubular ones up before it hits the road next time... partly just to hang some ancillaries off
#40
Posted 17 February 2013 - 11:49 AM
no the identity of a vehicle is down to the DVLA , the clue is in the name Driver and Vehicle Licensing Agency
#41
Posted 17 February 2013 - 12:03 PM
we need someone with the inner wings cut away to be brave enough to ring DVLA and say i think my car fails the 8 points system do you want a look
any takers ?
#42
Posted 17 February 2013 - 12:04 PM
#43
Posted 17 February 2013 - 12:05 PM
#44
Posted 17 February 2013 - 02:50 PM
#45
Posted 17 February 2013 - 03:59 PM
