Stub Stack Or Ram Pipe
15 replies to this topic
#1 Bradders94
Bradders94
  • 56 posts
Posted 11 February 2013 - 10:59 PM
hi all ive bought a K&N con air filter for a HIF44 carb, and to aid the intake even more i would like a stub stack or ram pipe.
would someone be able to point me in the right direction as i look at ram pipes and the seem to be too long and i dont want to restrict air flow,
and stub stacks just look to small,
All help appreciated
Brad
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 11 February 2013 - 11:02 PM
a stubstack is just a small ram pipe that fits inside a filter
#3 holmesy
holmesy
  • 879 posts
Posted 11 February 2013 - 11:03 PM
depends whats your looking for? high end hp? low down torque? different lengths have different effects.
im sure cooperman will be along shortly to point you in the right direction.
med stubstack all the from me tho which has the correct eclipse as in the vizard book
#4 Bradders94
Bradders94
  • 56 posts
Posted 11 February 2013 - 11:06 PM
in what way does length affect? the longer the higher hp and the shorter for torque or visa versa :P and i'll have to have a read of the bible tomorrow and see whats what :)
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 February 2013 - 11:07 PM
MED stub stack, some of the others advertised are poor quality sand cast with near knife edge radius which is bad and not what a stub is all about air flow,
Stub stack is overhaul slightly better across the rev range, longer ram pipes are in a specific range.Ram pipes wont normally fit inside a filter on the carb
Edited by KernowCooper, 11 February 2013 - 11:10 PM.
#6 Bradders94
Bradders94
  • 56 posts
Posted 11 February 2013 - 11:14 PM
ahh i thought they looked a tad long for a filter, what sort of price is an MED stub stack??
#7 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 12 February 2013 - 10:43 AM
From a theoretical point of view;
Ram pipes are used to tune intake length for a specific rpm. Think of a wave moving up and down the pipe, if you get the high pressure at the valve end just after it opens you'll ram more air in, whereas if you get the trough there you get less air.
A stub stack is there to smooth the airflow into the carburettor by creating a more laminar flow, this should curve out and back on itself to at least 90 degrees from the carb intake.
Something like this;
#8 freshairmini
freshairmini
  • 1,718 posts
Posted 12 February 2013 - 11:52 AM
£25 from their website. You may find postage on top or it could be free, who knows!
http://www.med-engineering.co.uk/catalogue/ancillaries/ram-air-kits/med-stub-stacks
Edited by freshairmini, 12 February 2013 - 11:52 AM.
#9 ukcooper
ukcooper
  • 1,625 posts
Posted 12 February 2013 - 05:39 PM
that stub stack from med will not fit inside a k&n fillter for a hif38/44 unless you butcher it, summerford minis aparantly sell one that dose.
http://www.somerford...=184&chapter=50
one next to the red R, 3/4 the way down left side.
Edit = link
Edited by ukcooper, 12 February 2013 - 05:41 PM.
#10 rally1380
rally1380
  • 1,893 posts
Posted 12 February 2013 - 05:46 PM
Or buy the whole MED intake system...stub stack and filter + backplate and send the K&N's back.
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 February 2013 - 06:20 PM
Thats the one I had from someford not a quality item and poorly finished
#12 holmesy
holmesy
  • 879 posts
Posted 12 February 2013 - 06:40 PM
get the stubstack from med and the itg filter and backplate from camskill, thats what im doing. 45 quid for the filter and backplate and 25 quid for the stubstack. that means you save 20quid
#13 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Posted 12 February 2013 - 09:33 PM
The Somerford stack is awful quality, but will fit the k&n. I gave mine a good going over with wet and dry and it came up ok.
#14 Bradders94
Bradders94
  • 56 posts
Posted 12 February 2013 - 11:46 PM
thanks for all the advice guys, may i ask why the MED doesn't fit inside a K&N??
#15 Mrpeanut
Mrpeanut
  • 1,019 posts
Posted 12 February 2013 - 11:54 PM
^^^ because its massive! You need a tiny one like somerford do. I'm not sure there's another on the market that'll fit the k&n.
