Nodiz Group Buy
211 replies to this topic
#31 t@z
t@z
  • 1,712 posts
  • Local Club: www.turbominis.co.uk
Posted 11 February 2013 - 10:12 PM
in order to get the temps you will need bosch sensor which matt has supplied the sensor no. on his forum if you go looking you will find it there. one thing to bear in mind is the the thread of these sensors is different to that of the mini head or anything that i've seen so you will prob have to make your own adaptor as i am.
lastly guys go to the forum and do reading before you start asking silly questions and being lazy. all the info is there it just means you have to pull your finger out your ass and do some homework for once ;)
Edited by t@z, 11 February 2013 - 10:13 PM.
#32 t@z
t@z
  • 1,712 posts
Posted 12 February 2013 - 10:02 AM
for holmesy from matt
could you let connor (holmsey) on the mini forums know I have give the go ahead for the group buy
#33 holmesy
holmesy
  • 879 posts
Posted 12 February 2013 - 12:50 PM
thanks T@Z i did check last night.
Can i get a list setup please.
I'm in, please state if your in or possibly in, if i get to four certain people in and cant get a 5th i will call dad in to get one for himself :P
#34 holmesy
holmesy
  • 879 posts
Posted 12 February 2013 - 12:51 PM
1: Holmesy
2:
3:
4:
5:
#35 james962
james962
  • 2,677 posts
Posted 12 February 2013 - 01:29 PM
Could you find out exactly what is included for the £255? Is it just the ECU, MAP/TPS sensor, and wiring loom?
I, like others I assume who are looking at this, is currently running on the Dizzy. Therefore, further to this, we will need:
1) Trigger wheel
2) Crank sensor (which ones are recommended and compatible with Nodiz?)
3) Crank sensor bracket
4) Ford Coil pack
5) Ford HT leads
6) Dizzy hole bung
Anything else? Just want to be 100% sure before I commit, and I'm sure other may find this post useful?
#36 motorsportelectronics
  • 54 posts
Posted 12 February 2013 - 01:57 PM
1) Trigger wheel
4) Ford Coil pack
5) Ford HT leads
6) Dizzy hole bung
James,
The system includes unterminated loom, USB Dongle and the NODIZ Pro.
In answer to your questions:
1) Trigger wheel - You will a 36-1 type
2) Crank sensor (which ones are recommended and compatible with Nodiz?) We reccomend Ford Mondeo/Focus type, see below.
3) Crank sensor bracket - Again need to make
4) Ford Coil pack - See below
5) Ford HT leads - See below
6) Dizzy hole bung _ To make
We offer a new ford coil pack, leads and crank sensor for £65+VAT, which may save hassle. We are looking into creating an A series specific kit of parts (brackets etc), but that most likely wont be available for this group buy.
Regards,
Matt
#37 kappa
kappa
  • 1,301 posts
Posted 12 February 2013 - 05:37 PM
1: Holmesy
2: Kappa
3:
4:
5:
#38 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 12 February 2013 - 08:54 PM
Just doing abit of digging into this but im very interested.
#39 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 12 February 2013 - 09:07 PM
Would the NODIZ Pro™ Complete Package be everything needed to set up and go? Or would I still need to acquire extra parts? And just confirm i could run this on a 1380cc A+ with a HIF 44?
#40 kappa
kappa
  • 1,301 posts
Posted 12 February 2013 - 09:19 PM
This is a quote from
Regards,
Matt
#41 holmesy
holmesy
  • 879 posts
Posted 13 February 2013 - 08:05 PM
dont let this die guys
#42 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 13 February 2013 - 09:53 PM
1: Holmesy
2: Kappa
3:o0OWILKSO0o
4:
5:
#43 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 14 February 2013 - 03:27 PM
I'd like to join in on this but where in west yorkshire could i get it mapped? I'm defo interested in a complete kit. Failing that i could get a Specialist Components tigger wheel kit.
Edited by DannyTip, 14 February 2013 - 03:28 PM.
#44 holmesy
holmesy
  • 879 posts
Posted 14 February 2013 - 05:58 PM
if you can get to Wiltshire then matt has offered to map and set the carbs up for free for the first of us to make it there. if not pop a post up for local rr that are mini and engine management friendly. There are plenty of guys on here that I am sure will point you in the right direction
#45 holmesy
holmesy
  • 879 posts
Posted 16 February 2013 - 09:33 AM
should I add you to the list then dannytip?
