Nodiz Group Buy
#196
Posted 23 September 2013 - 08:51 AM
the car is going for rolling road session on the 29th at the Snetterton Speed Shop (john lewis's new workshop who is leading the miglia series at the moment) I believe it will also feature in mini mag under the club rolling road.
#197
Posted 23 September 2013 - 08:55 AM
#198
Posted 23 September 2013 - 09:16 AM
I'm very interested in the micro. Have already spoken to Matt as he's only a couple of miles away from me and with any luck I might get to do some testing. If I get my hands on one I'll put a build thread up here
#199
Posted 23 September 2013 - 10:26 AM
#200
Posted 24 September 2013 - 12:52 AM
#201
Posted 07 October 2013 - 06:12 PM
#202
Posted 07 October 2013 - 09:56 PM
What's the new Micro then Holmesy?
For the coil pack, I just fabricated a small bracket to mount onto the transfer case, fits nicely infront of the servo.
#203
Posted 08 October 2013 - 08:33 AM
From facebook...
#204
Posted 08 October 2013 - 02:06 PM
Still not sure on weather to run megajolt or Nodiz on my turbo build
#205
Posted 24 February 2014 - 08:56 PM
Finally my engine is going back in. Does this look right for the sensor.....
#206
Posted 25 February 2014 - 08:50 AM
Can you get a feeler gauge between the sensor and trigger wheel? Be carful when measuring as the sensor is magnetic and will attract the feeler gauge. Aim for <1mm.
Once set, it is worth turning the engine once to check that the trigger wheel is bolted central as you don't want it to take out the sensor.
#207
Posted 25 February 2014 - 08:53 AM
If you use washers instead of nuts to space out the sensor, you will be able to get a closer tolerance.
#208
Posted 25 February 2014 - 01:50 PM
#209
Posted 11 June 2017 - 01:30 PM
thank you all.
Edited by 89mini30, 11 June 2017 - 03:05 PM.
#210
Posted 11 June 2017 - 02:47 PM
Hi there James, I now own G962 and after a short run today its running very rough. I can see two wires coming from the nodiz ( pink/purple) that dont go anywhere, should they?
