Nodiz Group Buy
211 replies to this topic
#181 kappa
kappa
  • 1,301 posts
Posted 03 April 2013 - 09:07 PM
Was not hard to set up at all really. The main unit you have 12v feed, earth, coil A, coil B, cranks sensor and vacuum hose to connect up. The coil A and B go to the coil pack, and you also need a 12v feed to this as well (middle connector). Remember that the Nodiz unit needs a 12v feed whilst cranking....this had me stumped for a few mins :lol:
One thing you need to think about is without the standard coil, there is no coil -> starter solenoid wire, so you will also need to trace one of these (ignition live).
Here are a few pictures of the various parts of my install:
MED trigger wheels, crank sensor bracket & sensor
I used a Ford Ka coil pack and HT leads. Bought both from Eurocarparts. Couldn't see the point at this stage to buy secondhand. Sourced a proper coil pack connector, and 2 pin junior connector for the crank sensor from PoleVolt.
Dizzy bung from DNS classics
Coil pack mounting
Nodiz unit mount
Final picture all assembled
Video of the engine running
Very nice, I am liking it
#182 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 03 April 2013 - 10:18 PM
Nice one, seems to run nicely at idle, I take it your getting it on the roller with matt next.
#183 mini*mad
mini*mad
  • 423 posts
Posted 03 April 2013 - 10:29 PM
I am up for giving this a go
But may go megajolt depending on a few tests of both
Looks good though
#184 motorsportelectronics
  • 54 posts
Posted 04 April 2013 - 11:51 AM
Nice work James!
Please post it up on the NODIZ.co.uk forums also please :D
Cheers,
Matt
#185 holmesy
holmesy
  • 879 posts
Posted 04 April 2013 - 01:56 PM
looking good, still trying to find a suitable map for mine, did find one for my spec but it had something stupid like 42 degrees advance at high load and RPM :o .
will most likey end up making my own, hope top get it coil and nodiz mounted this weekend but have been so busy at work lately that i have no time.
#186 james962
james962
  • 2,677 posts
Posted 04 April 2013 - 03:01 PM
I'm just running off the base map which was provided on the Nodiz unit at the moment, it is quite a conservative map. The video was the second time the engine was running, first time was the base timing to set TDC, and then the above video - so engine was stone cold and started straight and idled at about 900-1000 nice and smooth with a bit of choke out.
Matt, I've sent you a PM :thumbsup:
#187 james962
james962
  • 2,677 posts
Posted 09 April 2013 - 12:12 PM
Matt, did you get my message about getting it mapped?
Also, I've had a play around with the Andriod app on the Mrs' phone, which works fine, but how do you toggle the rpm read out to mph?
#188 motorsportelectronics
  • 54 posts
Posted 11 April 2013 - 05:24 PM
James, yes sorry got your PM, been manic here!
You cant do MPH at the moment, as we are working on a better way of doing it as well as displaying fuel level :)
Matt
#189 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 17 April 2013 - 03:35 PM
James what is the part number for the KA coil pack??
#190 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 17 April 2013 - 04:55 PM
Is this the coil pack you used??
http://www.eurocarpa...887d12ad
#191 james962
james962
  • 2,677 posts
Posted 17 April 2013 - 08:57 PM
Yes mate, that's the one.
I also used these leads:
http://www.eurocarpa...1f005774
I think at the time I bought them, ECP had a 50% off service items, so got them quite cheap, although they seem to always have one promotion on or another!
#192 motorsportelectronics
  • 54 posts
Posted 18 April 2013 - 01:32 PM
I believe James is booked in for his mapping session ;)
#193 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 20 April 2013 - 06:45 PM
Progress finally, last few days ive put a few hours in, decided the engine is coming fully out and ill kill a few birds. Firstly...
will go DSN once im happy.
Also just ordered the coil pack and leads that james recomended. Hopefully tomorrow the cog and sensor will be fitted. But I will probally just get sidetracked with cleaning parts.
#194 holmesy
holmesy
  • 879 posts
Posted 16 July 2013 - 02:51 PM
all up on running on mine, wouldnt even bother starting on the base map for me lol, after an hour of making a map and then starting it i had a issue with idle but with the idle screw wound in a turn and a half its now running lovely :D pulls a lot stronger and runs smoother too. still need some tweaking
#195 james962
james962
  • 2,677 posts
Posted 24 July 2013 - 10:01 AM
hows it going Holmesy?
