Nodiz Group Buy
211 replies to this topic
#136 holmesy
holmesy
  • 879 posts
Posted 04 March 2013 - 10:37 AM
haha small world :P
i believe i have got the late style coil pack where the leads dont click in so will see if i can open up my leads to fit :)
#137 motorsportelectronics
  • 54 posts
Posted 04 March 2013 - 10:54 AM
James,
Thanks have received the payment.
I haven't loaded the map onto any of the units, as I always send them out with the OEM test map which we use when testing them. I am however in the process of converting your map to a NODIZ map file which you can then upload at your leisure :)
Everyone should of either already received their units or be receiving them today, can you please confirm :)
Matt
Edited by motorsportelectronics, 04 March 2013 - 10:55 AM.
#138 holmesy
holmesy
  • 879 posts
Posted 04 March 2013 - 11:01 AM
hi matt, have you sent by royal mail or a courier service ?
#139 motorsportelectronics
  • 54 posts
Posted 04 March 2013 - 11:07 AM
All by APC courier, tracked and insured :)
Edited by motorsportelectronics, 04 March 2013 - 11:07 AM.
#140 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 04 March 2013 - 01:14 PM
I know you already know I got mine. But the postage was fast next day delivery.
Edited by dean, 04 March 2013 - 01:17 PM.
#141 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 04 March 2013 - 01:20 PM
holmesy one thing i will say, put your rad mount on the one with the engine mount attached, you will have to do some timming to make life easier to do a fan belt change in the future with the engine fitted, if you dont you may have to remove the mount or at least the top bolt to let the mount lean back to get space to get the fan belt past
just something i heard from some else who has done it
Told you so moment !!!! Ha ha.
Edited by dean, 04 March 2013 - 01:27 PM.
#142 james962
james962
  • 2,677 posts
Posted 04 March 2013 - 01:23 PM
Dean, where are you going to mount the actual Nodiz unit? I'm thinking inside the cabin somewhere out of the engine bay. Only problem being I don't have a dash, but want it out of sight - maybe mount it under the dash
#143 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 04 March 2013 - 01:30 PM
That's we're I was thinking. As far under as possible going to have a look tonight and test mount and find where go run cable, drill holes before it goes for paint.
I was thinking of mounting the coil pack off the front slam panel. In front of the grill. My car is a fair weather car so is not going to be getting wet much except for washes
Edited by dean, 04 March 2013 - 04:13 PM.
#144 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 04 March 2013 - 03:26 PM
Got mine today. Shame the car is in Germany and I'm in Dorset. Still need to get the coil pack and the sensor for the wheel tho. Any one got any links to get a decent sensor?
#145 james962
james962
  • 2,677 posts
Posted 04 March 2013 - 04:10 PM
Could use a sensor like here:
http://www.onlineaut...ft Sensors.aspx
or here:
http://www.ebay.co.u...a-/290614416044
I'm going to use a SEN8D sensor as this is what fits to my sensor bracket.
Trigger wheels also do a sensor and connector package for £20.
#146 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 04 March 2013 - 04:21 PM
I am also using a sen8d sensor as like you it fits my mount.
But if you look up trigger wheels they do a kit for the mini. Same kit that holmosy has fitted. Around £40 plus.
#147 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 04 March 2013 - 04:40 PM
Is this the right coil pack? The top one...
http://trigger-wheel...s/en-uk/d8.html
#148 james962
james962
  • 2,677 posts
Posted 04 March 2013 - 05:01 PM
The one pictured is a gen2 coil pack and I will be using one like this. the gen1 had "clip on" HT leads.
#149 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 04 March 2013 - 05:52 PM
Gen 2 just push on then?
#150 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 04 March 2013 - 06:46 PM
Yes it's that type of coil. Either the 1st or 2nd gen coil. You can also add a sensor and plug. from trigger wheels.
Found a good place to put the nodiz box. In the left hand pedal box hole , under the dash. Nicely hidden.
