Why Is It So Hard To Find An Engine Builder!?
#31
Posted 21 April 2014 - 08:01 PM
#32
Posted 21 April 2014 - 09:13 PM
Have you considered building it yourself and getting the machining done locally? It's a great learning experience and will save you lots of money
I can second that. Build it yourself one hell of a way to know your engine and learning how they work, never built an engine before but I have now and it won't be the last. Take your time, use some fore thought and you won't go far wrong. If I could pass on one bit of advice it would be take loads of pictures and clean everything thoroughly. Some of that build money you have put by could pay for some of the tools you will need.
Give it a go there is a great sense of achievement waiting to be had and you will be glad you did it yourself, because above all you know it will be right and yes you may make a few mistakes. I did but what the hell.
#33
Posted 22 April 2014 - 02:37 PM
For example, it is not possible to build a top quality engine for £1000, despite what anyone will tell you.
Is that parts and labour or just parts? I've been pricing up my Midget engine as I go along, with the planned parts still to buy/fit and it's coming out in the region of £1300, and I'm doing the work. Few ancilliaries to add to that like exhaust manifold, clutch ...
#34
Posted 22 April 2014 - 03:02 PM
You should be able to buy everything you need, including new cam, all bearings, gaskets, pistons, etc, for under £1000, unless you are building a race or rally engine, but the labour of, say, 30+ hours at whatever is being charged will always push the total price towards, or even over, £2000.
I'm sure there are builders who will 'throw together' an engine for less, but they won't set the deck height, renew the cam bearings, do proper 'trial-build(s), set the cam timing to +/- 1 degree, do all the compression ratio calculations and machine the head to suit, check each & every ring gap, check the bearing clearance with 'Plastigauge' if the crank is not to be re-ground.
In life you do get what you pay for.
#35
Posted 22 April 2014 - 03:34 PM
I guess it depends very much on how standard the engine you build is ... even a lightened duplex setup adds £7 to the bill ... and those £7s add up ... Which pistons can make a big difference too.
Mine should be a fast road engine ... at the moment it is a pile of various shaped lumps of metal .. (Pile as in not put together and not in as "piled" up in a dusty corner)
#36
Posted 22 April 2014 - 05:39 PM
#37
Posted 13 May 2014 - 08:58 PM
Sorry to drag up an old topic, but in the end I decided to build the engine my self. I've built a few mini engines before but never to the standard of this one. I've only just got it back on the road after around 18 months, but its been quite a transformation
Before
After
It turned into more than just an engine rebuild! lol
Oh yea, big thanks to Guessworks for building an excellent gearbox
