Why Is It So Hard To Find An Engine Builder!?
36 replies to this topic
#16 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 10 February 2013 - 10:00 PM
Have you considered building it yourself and getting the machining done locally? It's a great learning experience and will save you lots of money
#17 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 February 2013 - 10:04 PM
Paul Inch in Plymouth been doing minis when his father Chris ran the company in the 60/70s, Pauls son/daughter both race minis and they have a good name down in the SW
Paul built my engine and i'm very happy with his work
#18 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 10 February 2013 - 10:05 PM
ML Motorsport are full of road engines at the moment, no more capacity. ML specialize in road engines, that is why they are busy, more people need road based engines that race ones. Why the rush?
AC
#19 Noris8322
Noris8322
  • Just Joined
  • 201 posts
Posted 10 February 2013 - 10:25 PM
AC
I've heard some really good things about ML Motorsport and they always seem really helpful when I've spoke them at Southern Mini Days. Also they are less than 20 miles from where I live.
There is no real rush but wanted to get things underway, but I'm thinking of having the gearbox rebuilt (this is the main problem). Then checking the overall condition of the engine, replacing whats needed and putting it back in. Then trying to get my name on MLM's waiting list to have it rebuilt and modified at a later date
#20 Noris8322
Noris8322
  • Just Joined
  • 201 posts
Posted 10 February 2013 - 10:36 PM
This was my original idea, but then when you start taking compression ratios and precision measuring and cam timing. I think I would be in over my head, I thought it would be best left to the professionals. If it was a case of just assembling the engine and checking clearences then that wouldn't be a problem
#21 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 11 February 2013 - 01:11 PM
if you can wait why not let ML assist with your project?
AC
#22 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 11 February 2013 - 02:35 PM
Out of curiosity, what's the lead time on ML having space, AC?
I've just about got my new build spec'd up (subject to better suggestion) but am having difficulty in finding a builder it seems :)
#23 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 11 February 2013 - 02:52 PM
I think it is 3 months, call Andy at the workshop to discuss, 01474 825123.
AC
#24 JDImini
JDImini
  • 679 posts
Posted 20 April 2014 - 04:14 PM
Hi Noris8322, just wondering how the engine build went last year as I'm in the South and looking to have some engine work done. May well go to Ian Hargreaves as he lives round the corner and have met him a couple of times. He is a really nice person and has an absolute wealth of knowledge about minis
#25 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 20 April 2014 - 04:17 PM
Yup I am busy too, doing my own work and supplying ML Motorsport. Patience is key!
Ac
#26 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 20 April 2014 - 04:23 PM
I was going get someone to do my engine..
but thought thats silly, might aswell do it myself.. its learning curve, plus you know engine in and out...
Ive got local machining shops for the bits and bobs, but rest im.doing
#27 Cooperman
  • 23,278 posts
Posted 20 April 2014 - 05:01 PM
The reason good engine builders can be hard to find is that too many classic car owners with A-Series engines want them done 'on the cheap'.
When I retired a few years ago I decided that I would build a few engines. However, too many people didn't want to pay for a 'proper' job, so I decided that as I was supposed to be retired, I would do just that and now I just build engines for myself & my friends, plus work on diesel engines at my gliding club (changed a diesel Land Rover cam belt today).
For example, it is not possible to build a top quality engine for £1000, despite what anyone will tell you.
#28 JDImini
JDImini
  • 679 posts
Posted 21 April 2014 - 03:40 PM
Hi Cooperman
very interested in your comment, what should you budget for a good 998 road engine?
#29 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 21 April 2014 - 04:09 PM
I would do it yourself mate, im just after building mine with no previous experince and its turned out great, just do the research into endfloats etc and give it a go! Its not a dark art or rocket science just do the research and take your time! Who knows you might even enjoy it and if you just give it to someone else you arent learning anything or gaining experience
#30 Cooperman
  • 23,278 posts
Posted 21 April 2014 - 07:19 PM
First of all do a parts costing using, say, Mini Sparesweb site.
You will need:
Pistons
Main & big-end bearings
Crank thrust bearings
Camshaft & followers
Oil pump
Water pump
Full gasket set
Full set of valves & valve guides
Timing chain & tensioner (or Duplex chain kit)
Primary gear bushes
'Red' primary gear seal
Timing cover seal
Distributor re-build parts - points, condenser and possibly shaft & bushes.
Fan belt
Plus any other parts you decide to change(engine mounts for example).
Then add the labour. To build an A-Series properly, including all machining, measuring, trial build(s), final assembly and painting will take around 30 hours. If someone says they can do it quicker, then I would query how thoroughly they are doing it. Work on £35 to £40 per hour for the labour. If the head needs full gas-flowing as well as just guides & valves, add another 8 hours to the total.
If doing the gearbox as well, allow around £350 to £500 for a full re-build as a standard gearbox (check with 'GuessWorks' for an accurate price).
When you have done that you will see why so many learn to build their own engines, sub-contracting the machining to a reputable firm like AC Dodd, Rob Walker Engineering or similar company.
This is just a guide and labour times may vary, but not by much as it takes time to do a 'proper' job.
